Hello everyone,
This is just a general question. I'm not saying I have a problem, I'm only asking out of curiosity.
To calibrate my extruder, I will remove my Bowden tube from my hotend assembly, then send "G1 E100 F120". I will then use my calipers and measure what came out. I will do this 10 times, then average the results. I will take that value, then figure out the percentage of how off I am. Then I will change the steps to match. After the change I will double check to see if the change worked.
I will then print a 20mm cube, with one 0.5mm thick wall, no infill, no top or bottom. I then measure (3 places per side) the thickness of the wall. My measurements are always over the 0.5mm thickness I set. I've seen at times 0.6mm thick spots.
So my question is... What is you tried and true way to calibrate your extruder? Do you try to get 100mm out of your extruder? Or do you try to make the walls the correct thickness?
Thanks
TC
