I'm moving this from a machine specific sub forum as I'm told it was a redundant but of kit.
I'm hoping for a recommendation for a relatively simple and inexpensive build.
I'm in the UK and have no access to a printer so I'll need to buy some printed parts but most other bits I can source locally or from evilbay.
The other limitations are cost, it needs to be inexpensive and require only simple tools to build.
I'd like a heated plate and decent software I don't need any large print volume but I would like to be able to reuse parts if I decide to build a bigger printer.
So with those limitations what can you recommend and were can I get the printed bits?
If a scratch build is too much over the cost of a kit I'll do a kit, but which one and can you recommend a supplier in the UK.
Thanks All. Aamcle
