Ender 3 Y axis problem August 09, 2018 05:20AM |
Re: Ender 3 Y axis problem August 09, 2018 05:31AM |
Re: Ender 3 Y axis problem November 08, 2018 12:19PM |
Re: Ender 3 Y axis problem February 02, 2020 02:40AM |
o_lampe
If one axis is tight and binding, you often see shifted layers. (search 'skipped steps' too )
When the walls of the cube are vertical, but too small you can recalibrate the axis. Put the new found steps/mm in the startcode of your slicer ( M92 Y####) or overwrite the eeprom. (Send M92 Y#### and M500 directly from Pronterface or other terminal)
Re: Ender 3 Y axis problem February 02, 2020 02:47AM |
pliers
I've just got an ender 3 and whilst assembling it I noticed that the belt rises a bit between the line of the pulleys, so as such I suspect there may be some very slight distortion of prints along the Y axis depending on how far the print is from the highpoints of where the belts attach, I think adding a small idler and elongating the holes for adjustment may solve the issue if there is room to do so the other issue I have is the pulleys are a press fit on mine so fitting dampers is going to be fun
