Bug in Marlin autoleveling? August 10, 2018 08:40PM |
Re: Bug in Marlin autoleveling? August 13, 2018 11:48AM |
Re: Bug in Marlin autoleveling? August 13, 2018 03:33PM |
Re: Bug in Marlin autoleveling? August 14, 2018 05:42PM |
Re: Bug in Marlin autoleveling? August 14, 2018 05:59PM |
Re: Bug in Marlin autoleveling? August 14, 2018 06:09PM |
Re: Bug in Marlin autoleveling? August 14, 2018 06:19PM |
Re: Bug in Marlin autoleveling? August 14, 2018 06:23PM |
Re: Bug in Marlin autoleveling? August 14, 2018 06:24PM |
Re: Bug in Marlin autoleveling? August 14, 2018 07:04PM |
Re: Bug in Marlin autoleveling? August 15, 2018 12:25PM |
#define DEFAULT_NOMINAL_FILAMENT_DIA 3.0
#define DEFAULT_MAX_FEEDRATE { 250, 250, 4, 22 } // change z back to 2
//#define MULTIPLE_PROBING 2
#define AUTO_BED_LEVELING_LINEAR
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR) // Set the number of grid points per dimension. #define GRID_MAX_POINTS_X 3 #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X // Set the boundaries for probing (where the probe can reach). //#define LEFT_PROBE_BED_POSITION MIN_PROBE_EDGE //#define RIGHT_PROBE_BED_POSITION (X_BED_SIZE - MIN_PROBE_EDGE) //#define FRONT_PROBE_BED_POSITION MIN_PROBE_EDGE //#define BACK_PROBE_BED_POSITION (Y_BED_SIZE - MIN_PROBE_EDGE) // Probe along the Y axis, advancing X after each column //#define PROBE_Y_FIRST #if ENABLED(AUTO_BED_LEVELING_BILINEAR) // Beyond the probed grid, continue the implied tilt? // Default is to maintain the height of the nearest edge. //#define EXTRAPOLATE_BEYOND_GRID // // Experimental Subdivision of the grid by Catmull-Rom method. // Synthesizes intermediate points to produce a more detailed mesh. // //#define ABL_BILINEAR_SUBDIVISION #if ENABLED(ABL_BILINEAR_SUBDIVISION) // Number of subdivisions between probe points #define BILINEAR_SUBDIVISIONS 3 #endif #endifYou define linear probing, but do not define the left/right/front/back edges. I would probably uncomment these.
Re: Bug in Marlin autoleveling? August 15, 2018 09:16PM |
