Did something dumb. Ever happen to you? August 14, 2018 05:54PM |
Re: Did something dumb. Ever happen to you? August 14, 2018 08:40PM |
Re: Did something dumb. Ever happen to you? August 14, 2018 09:06PM |
Re: Did something dumb. Ever happen to you? August 15, 2018 12:22AM |
Re: Did something dumb. Ever happen to you? August 15, 2018 04:39AM |
Re: Did something dumb. Ever happen to you? August 15, 2018 04:56AM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Did something dumb. Ever happen to you? August 15, 2018 09:07AM |
Re: Did something dumb. Ever happen to you? August 15, 2018 09:19AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Did something dumb. Ever happen to you? August 15, 2018 01:05PM |
Re: Did something dumb. Ever happen to you? August 15, 2018 01:14PM |
Re: Did something dumb. Ever happen to you? August 15, 2018 09:57PM |
Re: Did something dumb. Ever happen to you? August 16, 2018 10:21AM |
I even emptied the freezer, damnit.Quote
MechaBits
If you havent yet looked in the fridge your not trying hard enough.
Re: Did something dumb. Ever happen to you? August 16, 2018 11:30AM |
Re: Did something dumb. Ever happen to you? August 16, 2018 12:29PM |
Re: Did something dumb. Ever happen to you? August 16, 2018 01:39PM |
Re: Did something dumb. Ever happen to you? August 23, 2018 07:36PM |
imqqmi
I usually put things where I'd expect to find it if I'm looking for it. This sounds obvious, but when you think about it, how many times did you put things where you'd never expect to find it? It's usually when you are doing something vaguely related, got distracted and put things where you never put them.
So my strategy is to try to be concious what I'm doing even in the thick of things. Just stop, think and continue
imqqmi
Also, if you can't find where you expect it, but are sure it should be there, check the direct surroundings. Things slip off tables, drop out of boxes so look behind, under and around boxes etc and on the floor. 9 out of 10 I can find back what I need.
Re: Did something dumb. Ever happen to you? August 27, 2018 03:51AM |
Re: Did something dumb. Ever happen to you? August 27, 2018 04:25AM |
Re: Did something dumb. Ever happen to you? August 27, 2018 02:30PM |
Re: Did something dumb. Ever happen to you? August 28, 2018 05:10AM |
Re: Did something dumb. Ever happen to you? August 28, 2018 06:37AM |
Re: Did something dumb. Ever happen to you? August 28, 2018 08:42AM |
Re: Did something dumb. Ever happen to you? August 28, 2018 03:29PM |
Re: Did something dumb. Ever happen to you? September 06, 2018 10:11PM |
Re: Did something dumb. Ever happen to you? September 07, 2018 01:55AM |
SupraGuy
No 'magic smoke' involved in my forgetfulness. I am not the type to indulge in such, and I can't see that changing even with the imminent legalization of such here in Canada. I can't even blame the vodka in which I do occasionally indulge.
Re: Did something dumb. Ever happen to you? September 07, 2018 05:04AM |
Re: Did something dumb. Ever happen to you? September 10, 2018 12:17PM |
Re: Did something dumb. Ever happen to you? September 10, 2018 02:35PM |
