your thermistor wires for your hot end are shorted togeather
Often this is the screw holding the thermister in place is shorting them, or the thermistor legs are twisted together and touching
Some times it can even be the controler IO pin has died... (swap the bed thermistor on to the hot end plug and verify it reads room tempature (or close enough) , then swap it back before you forget)
