heat hotend without doing print how??
Posted by the robobuilder
August 23, 2018 12:04PM
ok so i am getting jam in my nozzle and to solve this i have to heat the hotend first so i dont know how to heat only hotend without printing any object???
Re: heat hotend without doing print how??
August 23, 2018 12:13PM
use your control panel of choice most have a manual GUI where you can set temperature
eg pronterface or cura
Or use gcode M104 S190 [reprap.org]
threw command line also threw a control panel.
Or if you have an lcd, most have a set temperature option in there also.
Edited 1 time(s). Last edit at 08/23/2018 12:16PM by Dust.
August 23, 2018 12:19PM
ok so when my temparature reaches to some degree then will it automaticaly stops heating?? or i have to send some commands to stops it???
August 23, 2018 01:35PM
It will stop at the desired temperature and apply heat as necessary to maintain that temperature from then on until you issue a command to stop heating.
... if everything is working properly of course smiling smiley
August 23, 2018 02:35PM
thankssmileys with beer
