Help needed with MKS Gen v1.4
Posted by mokush
August 24, 2018 05:20AM
Hello All!
I'm about to replace the Trigorilla Pro (crap) in my Anycubic i3 Mega. I have in the printer 2 Z motors and 2 Zmin endstops - by this the X rods are always in perfect level.
I plan to use:
- MKS Gen v1.4
- 4xTMC2208 (X, Y, Z1, Z2)
- 1xLV2789 (E)
- MKS TFT32
As I found no info about it, I'd like to ask:
- can this board hande 2 Z motors (I assume yes, Z and E1 configured to Z2 in the FW)?
- can this board handle 2 Zmin endstops? Is it possible to configure one of the free endstop connectors as Z2min?
- as I see there is only 1 fan connector on the board. How can I connect a hotend cooler (on and 100% RPM after hotend temp > eg. 40°C) and a layer fan with controllable on/off and RPM?
If the parts I mentioned above cannot fulfil the needs, can you recommend an other budget board that will?
Thank you in advance!
Re: Help needed with MKS Gen v1.4
August 24, 2018 09:09AM
mokush
Or you may connect your Zs in parallel or in series to Z or use CNC shield to connect both to separate drivers.
mokush
Yes the second Zmin is called "Zmax" or "Xmax" just configure them in Marlin for dual stepper configuration in "Configuration_adv.h":
#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
  //#define Z_DUAL_ENDSTOPS
  #if ENABLED(Z_DUAL_ENDSTOPS)
    #define Z2_USE_ENDSTOP _XMAX_
    #define Z_DUAL_ENDSTOPS_ADJUSTMENT  0
  #endif
#endif
mokush
You connect heatbreak cooler directly to 12V so it is always "on"
mokush
I personally like KFB 2.0, but MKS 1.4 should be fine for you.
August 27, 2018 09:29AM
Thank you!
