Help me with my 3D printer August 28, 2018 02:32AM |
Re: Help me with my 3D printer August 28, 2018 02:49AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Help me with my 3D printer August 28, 2018 03:22AM |
Re: Help me with my 3D printer August 28, 2018 03:30AM |
Re: Help me with my 3D printer August 28, 2018 03:49AM |
Re: Help me with my 3D printer August 28, 2018 05:02AM |
Re: Help me with my 3D printer August 28, 2018 05:47AM |
Re: Help me with my 3D printer August 28, 2018 05:51AM |
Re: Help me with my 3D printer August 28, 2018 06:15AM |
Re: Help me with my 3D printer August 28, 2018 07:55AM |
Re: Help me with my 3D printer August 28, 2018 03:04PM |
Re: Help me with my 3D printer September 01, 2018 01:32AM |
Re: Help me with my 3D printer September 01, 2018 02:16AM |
Re: Help me with my 3D printer September 01, 2018 03:30AM |
Re: Help me with my 3D printer September 01, 2018 03:56AM |
Dust
firstly you need to get endstops working, if these are wrong, nothing will move
so plug your endstops in (make sure you plug them in correctly, plugging them in backwards will destroy the voltage regulator on the mega)
Then test them
send the controller a "M119" command it should reply with the status of all your endstops
They should all be open at this stage
Then hold one endstop shut and send annother "M119" the axis endstop you are holding should now say triggerd
test each endstop.
#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.and change to true any that are currently backwards.
#define USE_XMIN_PLUG #define USE_YMIN_PLUG #define USE_ZMIN_PLUG //#define USE_XMAX_PLUG //#define USE_YMAX_PLUG //#define USE_ZMAX_PLUG
Re: Help me with my 3D printer September 02, 2018 01:10AM |
Re: Help me with my 3D printer September 03, 2018 01:47AM |
Re: Help me with my 3D printer September 03, 2018 03:05AM |
Re: Help me with my 3D printer September 04, 2018 01:33PM |
Re: Help me with my 3D printer September 05, 2018 01:18AM |
Re: Help me with my 3D printer September 05, 2018 01:26AM |
// Travel limits (mm) after homing, corresponding to endstop positions. #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0
Re: Help me with my 3D printer September 05, 2018 09:13AM |
Dust
2) it takes the home poistion to be what ever you set in marlin
so say your X endstop is at -15, then you should set #define X_MIN_POS -15
Re: Help me with my 3D printer September 05, 2018 10:02AM |
Re: Help me with my 3D printer September 05, 2018 10:27AM |
#define X_HOME DIR 1 #define Y_HOME_DIR 1 #define Z_HOME_DIR -1This will home to (or towards) 150,150,0 (Or whatever your X and Y size limits are.)
#define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1
Re: Help me with my 3D printer September 05, 2018 11:42AM |
Re: Help me with my 3D printer September 05, 2018 12:00PM |
Re: Help me with my 3D printer September 05, 2018 12:04PM |
Re: Help me with my 3D printer September 05, 2018 12:25PM |
#define INVERT_Z_DIR
Re: Help me with my 3D printer September 05, 2018 12:54PM |
Re: Help me with my 3D printer September 05, 2018 03:22PM |
G28 ;home all axes G1 Z10 ;lift Z axis to 10mm G1 X0 Y0 S1 ;move to XY origin G1 X150 Y0 ;move across the X axis G1 X150 Y150 ;move across the Y axis G1 X0 Y0 ;move diagonally back to the origin
