New Printer Design - Could do with some feedback / thoughts on spec! September 16, 2018 10:09AM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 16, 2018 03:51PM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 17, 2018 01:47AM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 17, 2018 07:10AM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 17, 2018 03:41PM |
CoreXY is fine, but moving the whole thing? No thanks. Moving the bed in the Z axis would be so much better. Lifting the CoreXY 8n the Z axis defeats the whole purpose of not having the motors moving.
For the Z rails, (Well moving rails on any axis, really) careful alignment is needed, to reduce wear and noise, but a careful fixed alignment is usually good enough. Some compliance in the bearing or rollers can make up for small imperfections and avoid transmitting any artifacts to the print.
I'm not saying a delta can't produce good prints, a "sloppy" delta can probably produce prints that are good enough for me, but I don't know what your standards are like.
You don't need/want 4 linear guides for the Z axis. One near each screw is all you need. Linear guides provide guidance, they don't keep the bed from tilting. Using 4 of them is going to be an alignment nightmare. Even if you manage to get them aligned, when room/machine temperature changes, the guides will move apart when warmed and closer together when cool and the whole thing may come to a grinding halt. Quality linear guides are great bearings but very intolerant of misalignment.
If you get the stuff with square ends and matched lengths you can bolt it directly together and skip the corner plates.
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 17, 2018 04:30PM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 17, 2018 04:31PM |
Ed3D
My fear exactly - would two central rails (like in the images) work ok? Im concerned about the bed tilting either way! Is thermal expansion a major concern though? I will be printing mostly PLA and not in an enclosure!
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 18, 2018 04:31PM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 19, 2018 07:11PM |
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 20, 2018 06:07AM |
gtj
If you use 3 Z leadscrews/motors instead of 2 (1 in the center back and 1 in each front corner) and you use a probe on the hotend, you can take advantage of auto bed levelling.
Re: New Printer Design - Could do with some feedback / thoughts on spec! September 20, 2018 03:38PM |
gtj
