An open source kiln as part fo the RepRap project? September 16, 2018 11:14AM |
Re: An open source kiln as part fo the RepRap project? September 16, 2018 11:18AM |
Re: An open source kiln as part fo the RepRap project? September 16, 2018 01:10PM |
Re: An open source kiln as part fo the RepRap project? September 16, 2018 02:15PM |
Re: An open source kiln as part fo the RepRap project? September 16, 2018 04:11PM |
Re: An open source kiln as part fo the RepRap project? September 16, 2018 05:03PM |
Re: An open source kiln as part fo the RepRap project? September 17, 2018 01:58AM |
Re: An open source kiln as part fo the RepRap project? September 17, 2018 01:29PM |
Re: An open source kiln as part fo the RepRap project? September 17, 2018 01:56PM |
John Cummings
Hi all
What do people think? How could I start something like this on the RepRap wiki? Does it fit? My only other idea of a place it could go is Open Source Ecology, but their forums don't seem to work any more which is a shame,
Thanks
Re: An open source kiln as part fo the RepRap project? September 17, 2018 03:16PM |
Admin Registered: 13 years ago Posts: 730 |
Re: An open source kiln as part fo the RepRap project? September 22, 2018 06:41PM |
Re: An open source kiln as part fo the RepRap project? September 23, 2018 09:50AM |
John Cummings
Thanks very much all, I've made a start on an outline here [reprap.org] please do add to it
Re: An open source kiln as part fo the RepRap project? September 24, 2018 01:15AM |
Re: An open source kiln as part fo the RepRap project? October 14, 2018 05:53PM |
Re: An open source kiln as part fo the RepRap project? October 16, 2018 10:05PM |
Re: An open source kiln as part fo the RepRap project? October 17, 2018 01:45AM |
Trakyan
Induction heaters can't be used to burn out molds etc. They can only heat conductive materials, and even then they tend to only be very effective with steels and iron, stuff like aluminium (which is what most hobbyists seem interested in due to a lower melt Temp) doesn't interact with the induction heater coil as much and therefore doesn't heat up as much.
Re: An open source kiln as part fo the RepRap project? October 18, 2018 09:22PM |
Re: An open source kiln as part fo the RepRap project? October 19, 2018 02:01AM |
Trakyan
Fair point then, I haven't used the commercial offerings but from what I've seen and done Aluminium is harder to heat. Also why induction stovetops don't work so well or at all with plain Aluminium pans or pots. I'm sure you can use a more powerful induction heater, but that all adds cost, complexity and makes it a bit more dangerous. I still reckon a regular heater is the best bet. Works equally well with all materials, cheap and not EMI to worry about.
Re: An open source kiln as part fo the RepRap project? October 20, 2018 11:26AM |
Re: An open source kiln as part fo the RepRap project? October 22, 2018 11:35AM |
Re: An open source kiln as part fo the RepRap project? October 22, 2018 02:50PM |
