Thinner Filament.
Posted by uticatechclub
Thinner Filament.
September 19, 2018 10:02PM
Greetings to All of you!
Do any of you heard of a filament (PLA in particular) that is thinner than 1.75 mm?
Is it possible to purchase it somewhere?
I can't get away form the idea of developing very light weight direct drive extruder paired with 0.2 mm or even smaller nozzle.
It would be nice to print small parts with higher resolution.
I am aware that few tried forcing standard filaments through smaller nozzles. Most efforts were somewhat unsuccessful, due to significant strain on the extruder (and other factors).
Thank you in advance for any information.
Re: Thinner Filament.
September 20, 2018 12:16AM
I made my own 0.8mm filament and modified a 0.4mm nozzle with a brass insert. It works quire well with a pancake Nema 17 stepper, but the drive gear teeth bit too deep and I had to experiment with other gears. It also tends to jam when the filament guide isn't perfect.
Edited 1 time(s). Last edit at 09/20/2018 12:17AM by o_lampe.
September 20, 2018 02:45AM
The motor power required is mainly a function of the extrusion flow. If you reduce the filament diam., you will have to run at a higher speed to keep the same flow !
My current direct drive extruder (with a NEMA 14 l= 28mm), hot end, fan, X carriage, Z homing sensor etc... is about 200gr. To lower the mass without reducing the extrusion flow requires to go for a servo motor. The stepper motor is the heavy part and related to its power.
Now if you are OK for a lower flow, indeed you can scale down everything. 3D pen use a very small motor, yet a 1.75mm filament.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
VDX
September 20, 2018 03:36AM
... I have some ideas around "direct filament printing", where the filament is not melted in a hot chamber and extruded through a nozzle, but something like "direct" printing with thin wires (already in the "printing" diameter of e.g. 0.05mm), where the wire tip is positioned on the surface and while moving the head, melted with a laser and fed synchronously with slightly lower or higher speed to vary the diameter/volume of the melted track ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
September 20, 2018 12:02PM
Thank you MKSA.
You nailed it in your last sentence: "Now if you are OK for a lower flow, indeed you can scale down everything. 3D pen use a very small motor, yet a 1.75 mm filament."
I am OK with the fact that print speed will go down to achieve higher resolution. And I am very much embracing the point of scaling down everything.
What bothers me with 1.75 mm filament in such application is that area representing nozzle opening shrinks very rapidly:
1.75 mm diameter represents area of 2.41 mm^2
0.4 mm nozzle opening provides area of 0.126 mm^2 --------------------------------------> ~15 times smaller
and proposed 0.2 mm nozzle provides area of only 0.031 mm^2 --------------------------------------> ~78 times (!) smaller
To obtain similar extruder dynamics (as how it relates to filament melting in heated space, retraction, pressure, etc.) one would want to keep the area relationship at ~15 (as shown).
It would imply that by using 0.2 mm nozzle and ~15 times area ratio, the new filament diameter must shrink from 1.75 mm to 0.77 mm.
Finding filament between 0.5 mm to 1.0 mm would make it very much feasible to experiment with higher resolution FDM.
I hope, I was clear enough to convey my point.
September 20, 2018 12:10PM
Thank you o_lampe.
I just noticed the link in your post leading to your previous work - very interesting...
I will take a good look at your findings.
September 20, 2018 03:12PM
Excellent research o_lampe!
Regarding your conclusions on drive gears and teeth:
May be we could make assumption (based on vast empirical work accomplished by RepRap community) that popular drive gears, their geometry and tooth configurations are quite usable with 1.75 mm filament.
Could it be also true, that reducing existing drive gear by the same ratio achieved by reducing 1.75 mm filament to 0.8 mm filament would be good enough? Am I over simplifying?
September 21, 2018 12:11AM
MKSA
I'm not good at math, but I doubt that.
I agree that melting power is proportional to extrusion flow, but from my experiments I've learned that the filament diameter has a significant impact on required motor power.
The torque of a current controlled e-motor is always max at low RPM and stays constant upto 50% of it's max. RPM.
Max RPM is proportional to V_motor. At 24V this means it can run faster than usually required for a extruder. E3D Titan is a good example.
You are right, that it has to run faster, but I say: it doesn't matter.
Edited 4 time(s). Last edit at 09/21/2018 12:18AM by o_lampe.
September 21, 2018 12:15AM
uticatechclub
I don't understand what do you mean with reducing the gear?
September 21, 2018 12:55AM
o_lampe
uticatechclub
I mean making it smaller proportional to how much smaller in diameter the new filament became.
September 21, 2018 01:40AM
It would be interesting to produce thinner filament on-the-fly from 1.75 mm or 3 mm filament, i.e. remelt into thinner filament before it moves into the hotend. This remelt should be done protected from oxygen.
You could
- change the filament diameter to fit your nozzle diameter and layer height, throughput
- mix filament with other filaments to get true color or material mixes anlogue to alloys
Edited 2 time(s). Last edit at 09/21/2018 01:43AM by JoergS5.
September 21, 2018 03:10AM
o_lampe
MKSA
I didn't say it is null, of course the thicker the filament, the less flexible it is and thus more force to drive it.
Still, (unless a poor hobgear and filament path)most of the force required is to push the filament in the hothend and extrude it through the nozzle. The thicker the filament, the lower its speed to get the same extrusion rate. Power is force X speed, torque X ω (in radians/s)
That means for a 3mm fil. you may have to use reduction gears to get the higher torque required. It is seen in 3mm extruder using Nema17 while the same motor can drive directly a 1.75mm. Steppers are a bit like gas engines, you need a gearbox to get its full power smiling smiley
Edited 4 time(s). Last edit at 09/21/2018 04:33AM by MKSA.
September 21, 2018 04:47AM
JoergS5
That was partly my 1st. idea, but pushing still hot filament through a Bowden tube is a no_go.
September 21, 2018 04:31PM
o_lampe
JoergS5
Yeah, youd have to miniaturize a a machine that is normally heavier than a 3d printer in order to do that
But i bet you could get the same effect by machining a cone shape into a volcano nozzle for example rather than the parallel sides that terminate in a your desired tiny nozzel,
September 21, 2018 07:19PM
'cat gut & rubber' wheels....maybe fine tooth metal,but i just like the sound of 'cat gut & rubber'
or some new cat gut variant? I know ppl have done it just not sure what the results where.
Edited 1 time(s). Last edit at 09/21/2018 07:20PM by MechaBits.
September 22, 2018 02:01AM
uticatechclub
o_lampe
uticatechclub
A finer pitch for the teeth would make sense, but reducing the diameter would cause more RPM for the same feed rate. Something like the Bondtech extruder would work. It would grip the filament from two sides.
September 22, 2018 03:53AM
o_lampe
A smaller diam also means less teeth contacting the filament. As a matter of fact I made a 12mm diam hobbgear (teeth made with a M3 tap) to get more grip. A lot simpler than the Bondtech approach smiling smiley Stays cleaner too !
September 22, 2018 06:06PM
if its too thin how would you stop it bunching up, would have to be a tight tolerance tube, and then as it gets near the heat would the filament have enough stiffness to create pressure?
September 23, 2018 01:58AM
That's why I chose 0.8mm filament. It matches 1mm ID Teflon tube. I was lucky to get a tube with 2mm OD. It fits inside the normal PTFE-heatbrakes.
It also needs proper guidance between gear and heatbrake to avoid spaghetti.
IMHO the chamber pressure can be much lower, since the cross-section of 0.8mm filament is so much smaller than 1.75 or even 3mm.
I had no problem with 1st. layer adhesion, but I have LokBuild on my printbed. PLA almost sticks too good on it.
September 23, 2018 03:45AM
o_lampe
Chamber pressure depends mainly on the nozzle diam and the extrusion rate (at the nozzle !). Now, the filament diam being smaller, the pressure being the same, the force is indeed reduced (prop to the diam ^2) .
An other thing, the smaller the filament diam, the more melted filament will be leaking up the heatbreak as people usually (unless you have very accurate drilling equipment) drill 2/10 mm more than the filam diam. For 1.75 I drill to 1.8mm then smooth the hole.
Anyway, buckling becomes the real killer and one has to reduce the distance from hobbgear to melt zone. This is why I don't like the E3D kind of attachment, heatbreak and heatsink that became the standard and made my own far shorter.
September 23, 2018 04:45AM
I am thinking about whether it's possible to press the melted filament into the nozzle with other measures than the extruder.
If melted material can be pressed by e.g. Argon to avoid oxygen reactions, you could make overpressure or underpressure to control the melted filament flow.
The reason I am thinking about this is to think about printing aluminium.
Edited 1 time(s). Last edit at 09/23/2018 04:48AM by JoergS5.
September 23, 2018 06:07AM
JoergS5
Done for metal using plasma, laser, ion beam deposition.
VDX mentioned his current work, laser plus "plastic" filament.
Edited 1 time(s). Last edit at 09/23/2018 06:08AM by MKSA.
September 23, 2018 02:02PM
MKSA
You mean laser plus metal powder? I mean melting metal (heat up with induction e.g.) and printing without laser.
Laser plus thermoplast is used at the FastFFF, it is a good idea.
Edited 1 time(s). Last edit at 09/23/2018 03:06PM by JoergS5.
VDX
September 23, 2018 02:05PM
... not powder - think about melting/fusing thin wires with the laser winking smiley
Viktor
September 23, 2018 02:21PM
VDX
Could you please show a picture or give my a youtube hint?
I know the HRL video, but this is powder imho.
=> I found your info on [reprap.org]
It is an interesting solution. The combination of different manufacture methods seems to open a lot of possibilities.
Besides welding I found the possibility of galvanic 3d printing, but it's very slow.
Edited 1 time(s). Last edit at 09/23/2018 03:00PM by JoergS5.
September 23, 2018 02:31PM
Sorry if I missed them in other threads (o_lampe), but what did prints look like, how often you use it, on what kind of parts.
Edited 1 time(s). Last edit at 09/23/2018 05:03PM by MechaBits.
VDX
September 23, 2018 04:15PM
... sorry, can't post more details or images as it's again an R&D project wit NDA's eye rolling smiley
Viktor
September 23, 2018 04:36PM
VDX
I understand. Good luck with it!
VDX
September 23, 2018 05:23PM
JoergS5
... to give you a hint into this direction - think about drastically speedup (or slowdown) galvanic or etching reactions with lasers winking smiley
Viktor
September 24, 2018 12:22AM
MKSA
Here is my direct extruder. The filament path can't be much shorter. It's driven by a 1A/13Ncm NEMA17 pancake. ( forgot the exact weight )
The 28BYJ you might recon' was a fail.
Edited 1 time(s). Last edit at 09/24/2018 12:24AM by o_lampe.
