closed loop gt2 timing belt length
Posted by Nikki81
September 29, 2018 08:20AM
I am building a new printer that uses closed loop gt2 timing belts but i am a bit confused about the length. If say for example a looped belt was advertised as 400mm long will the belt have a length between two points of 400mm or 200mm
Thanks Nikki
Re: closed loop gt2 timing belt length
September 29, 2018 11:34AM
Hi Nikki,
It would have about 200mm between two points, less so if you use pulleys of course.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
September 29, 2018 01:49PM
Thank you ! I can order my belts now and continue with my build
Nikki
September 30, 2018 11:10PM
splicing of belts is also possible, however it's not ideal and I tried several methods before I found one that seemed to actually stand up to regular use in my printer.
