What's the secret of belts running inside aluminum extrusions October 03, 2018 04:58PM |
Re: What's the secret of belts running inside aluminum extrusions October 03, 2018 05:25PM |
Re: What's the secret of belts running inside aluminum extrusions October 03, 2018 05:57PM |
Re: What's the secret of belts running inside aluminum extrusions October 03, 2018 06:48PM |
Re: What's the secret of belts running inside aluminum extrusions October 03, 2018 07:09PM |
Re: What's the secret of belts running inside aluminum extrusions October 03, 2018 08:01PM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 12:28AM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 02:21AM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 03:17AM |
o_lampe
[attachment 107420 twisted-belt-M3.JPG]
Maybe this design of my 'compact carrier' helps understanding? It is designed for 'Bosch slot5' extrusions and works surprisingly well on my Delta. They are made of PETG, which allows me to tighten the belt without breaking the clamping part.
[attachment 107421 twistedbelt.jpg]
@o_lampe To connect open belt together in a 'twisted' fashion, I simply CA-glued them. That's strong enough, but only works on straights. No bending allowed.
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 04:31AM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 06:54AM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 04:51PM |
Re: What's the secret of belts running inside aluminum extrusions October 04, 2018 10:40PM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 02:07AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 06:38AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 08:05AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 08:21AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 08:30AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 08:50AM |
leadinglights
No problems, I have had no failures in the belts on three printers. As I said though, toothed belt materials vary and rubber impregnated with a solid lubricant is is likely to have different adhesion to plain rubber. I would add to your comment though about jigs: It is useful not only to have a good cutting jig, but also a good assembly jig, especially with CA as the parts should be presented without any sliding movement and maintained under pressure until the bond has formed.
Mike
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 09:11AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 10:20AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 11:39AM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 12:28PM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 02:08PM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 02:16PM |
Re: What's the secret of belts running inside aluminum extrusions October 05, 2018 03:46PM |
Re: What's the secret of belts running inside aluminum extrusions October 06, 2018 06:47AM |
Re: What's the secret of belts running inside aluminum extrusions October 06, 2018 09:13AM |
Re: What's the secret of belts running inside aluminum extrusions October 14, 2018 08:21PM |
Re: What's the secret of belts running inside aluminum extrusions October 15, 2018 03:11AM |
MatthewHall
Archiclem... I built a printer in the design style of a Cetus. Here's the link to the respective forum thread. While I didn't put all the belts inside the extrusions, this might help. If you have any questions just ask.
And I nailed it this Weekend, I will post some pictures and design file soon... And i'm kind of going the "all metal way", using printed part only where I can't get metal to fit
