What's the secret of belts running inside aluminum extrusions
October 03, 2018 04:58PM
Hi everyone !
I'm currently building a crane style printer (a cetus ripoff to be completly honest)...
I know this is a flawed design (I mean cantilever... come on !) but I really like the compactness and minimalism of the overall machine...
Anyway... I find quite amazing the fact that They are able to run the belt inside the extrusion and yet, connecting it to an MGN12 carriage... I've looked again, and again, and I can't quite find the way they do it... So if you have a drawing, a link to a commercial product that does it... or a picture of your Cetus i would love it !
(I was wondering if they use some kind of crimping connector like these one [openbuildspartstore.com] )
Re: What's the secret of belts running inside aluminum extrusions
October 03, 2018 05:25PM
You simply use one large (the drive pulley) and two small pulleys (the far end) at the ends of the extrusion so the belt runs inside the slots.
October 03, 2018 05:57PM
I'm not sure to uderstand what you are saying, but i think their is a misunderstanding : I mean for me the problem is not the way you keep the belt inside the extrusion, it is how do you connect a belt in such a tiny space (inside the extrusion) to the mgn12 carriage... I cant believe this is achieved with a 3D printed piece...
I've tried many design and the "clamping the belt" part is always the problem, too big for being a 3D printed part inside an extrusion (especially if you use open belt, because you have to overcome the tensioning forces that tends to rip your connector apart !)...
I've spotted this design [www.thingiverse.com] but it does not fit into my aluminium extrusion... And I was wondering how a commercial printer did it !
I don't know if that's more clear...
October 03, 2018 06:48PM
Archiclem
There's absolutely nothing wrong with a cantilevered design as long as, like anything else, it is designed properly.
October 03, 2018 07:09PM
Just make a sandwich of a printed part which has the same profile of the belt, the belt, and an extension of the linear slide carriage. Use machine screws to hold it all together. The printed part and the belt should fit inside the extrusion.
p.s. What extrusion are you using? Can you provide a 3d model of the extrusion?
Edited 1 time(s). Last edit at 10/03/2018 07:11PM by etfrench.
October 03, 2018 08:01PM
@LoboCNC I know that a cantilevered design can be done the good way, It's going to be all metal connector, the main post being fixed on 6mm aluminium plate with countersunk screws... This is rock solid. I will do a thread once this is finished.
@Etfrench (are you french ? cause I surely am...) It's the motedis I type extrusion from here [www.motedis.fr]
They give an STP file... For the moment I havn't been able to crack down this particular matter, for obvious reasons, the rail must be 90° from the running belt... Anyway the space inside the extrusion is verry small, and you have to solve the open loop problem here too.
open | download - Motedis Profile 20x20 I-Type slot 5.stp (115.7 KB)
open | download - cetus knock off.png (97.5 KB)
October 04, 2018 12:28AM
Maybe this design of my 'compact carrier' helps understanding? It is designed for 'Bosch slot5' extrusions and works surprisingly well on my Delta. They are made of PETG, which allows me to tighten the belt without breaking the clamping part.
To connect open belt together in a 'twisted' fashion, I simply CA-glued them. That's strong enough, but only works on straights. No bending allowed.
Edited 1 time(s). Last edit at 10/04/2018 12:37AM by o_lampe.
October 04, 2018 02:21AM
No secret, plenty of "reum" (Inspector Clouseau dixit) to install a clamping attachment to the linear guide. Can be an Al corner with a plastic part with GT2 tooth profile to press it.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
October 04, 2018 03:17AM
o_lampe
[attachment 107420 twisted-belt-M3.JPG]
[attachment 107421 twistedbelt.jpg]
@o_lampe To connect open belt together in a 'twisted' fashion, I simply CA-glued them. That's strong enough, but only works on straights. No bending allowed.
this is very interesting indeed, but I have to questions, why would you need to twist the belt ? Is the friction not a problem ? What about the wear over time ? I never considered the fact that it could be a sliding part rather than a free "floating" connector.
@MKSA Yes that kind of what I have in mind, but I can't find a correct dimension piece of metal... I could try to fold one myself but that's another story...
October 04, 2018 04:31AM
Not french, US.
There's plenty of room in the channel for the belt and a locking piece. The channel is 5.1mm wide, so the belt will need to be smaller than that if you want it to ride at the top of channel. You could also mill or file the channel wider to take 6mm belt (Wood routers and tablesaws handle aluminum fine, just noisy and a little more dangerous. Aluminum needs to more securely held than wood). If the belt is at the top of the channel, the locking piece can be 4+mm thick. If the belt will ride entirely in the channel, the locking piece would be 2+mm thick. The locking piece can be as long as the carriage, and that should be enough to secure the ends of an open loop belt. Personally, I'd use a closed loop belt.
p.s. I'm pretty sure 20x20 extrusion isn't going to be rigid enough.
October 04, 2018 06:54AM
There's a twist in the belt so the teeth will interlock at the ends. If you don't mind the twist, just put the teeth together and fit them into a slot to keep them together. I would never trust CA glue to hold a belt.
I used this for the Z axis in UMMD and for the magnet carriage in a sand table:
No twisting needed. When you twist belts you may have problems with them riding on pulley flanges.
October 04, 2018 04:51PM
Due to the limited space, I would recommend printing the belt profile on the locking piece and use machine screws to hold the sandwich together.
October 04, 2018 10:40PM
Belts and tyres are made from the same/similar materials and puncture repair kits use what is effectively CA glue, so no problem with gluing them. Unless, as o_lampe mentioned, you expect the glued section to bend around a pulley or something (spoiler: it wont).
October 05, 2018 02:07AM
I made a closed loop GT2 belt using CA, the Loctite designed to make Orings and NO problem even going around pulleys after two years.
The trick is to properly prepare the end and of course for a belt you don't glue end to end like an Oring !
CA is really good on rubber. Of course not for PU belt !
October 05, 2018 06:38AM
Although toothed belt materials may vary, the ones I have tested may be unsatisfactory glued tooth to tooth with cyanoacrylate. This was because the toothed part was made of a rubber (neoprene) in granular form fused with a white waxy lubricant. The lubricant made for poor adhesion even with CA. The back surface however did not contain any lubricant and glued well with "Black Witch" neoprene glue. In a pull test to failure the glued joint did start to peel but nonetheless it held until the belt broke.
I glue my belts in this manner to run the back side of the belt over the idler pulley. I have gone away from using the twisted belt method, prefering to have one glued joint with the other ends held in a toothed tension adjuster - also back to back
Mike
October 05, 2018 08:05AM
Your problems come from improper preparation. You have to use a grinding wheel to remove the rubber on the back a bit more than 1cm on each end, till you reach the fibers. Then prepare a 2cm long piece by removing the tooth side till the fiber and glue this piece to join the belt. You need a jig to keep the pitch correct. The belt is jut a few tens thicker but it is OK as the fibers are on the same plane.
There are other techniques but requiring accurate jigs to cut interlocking profiles.
Edited 2 time(s). Last edit at 10/05/2018 08:09AM by MKSA.
October 05, 2018 08:21AM
No problems, I have had no failures in the belts on three printers. As I said though, toothed belt materials vary and rubber impregnated with a solid lubricant is is likely to have different adhesion to plain rubber. I would add to your comment though about jigs: It is useful not only to have a good cutting jig, but also a good assembly jig, especially with CA as the parts should be presented without any sliding movement and maintained under pressure until the bond has formed.
Mike
October 05, 2018 08:30AM
Remind me why your splicing belts? On the twin plates above i'd put a slot in one for the belt to come through then they end up face to face and you can pull tight easy.
Edited 1 time(s). Last edit at 10/05/2018 08:32AM by MechaBits.
October 05, 2018 08:50AM
leadinglights
Mike
Of course, I made these jigs to cut and assemble.
Now, here here he doesn't need all this as it is for closed loop belts. Someone just suggested to use this kind of belt when in fact it is not necessary.
Edited 1 time(s). Last edit at 10/05/2018 08:53AM by MKSA.
October 05, 2018 09:11AM
Although I don't know the design intended, I would find it unusual to find anything (e.g. a carriage) clamped onto a closed loop belt. I mentioned this only as a comment on DDs assertion that CA adhesive was unsuitable - my attitude being that the appropriate adhesive will work well but depends on the material.
MechaBits, I am assuming you are commenting on my photo in a posting above so perhaps I should clarify. The two plates form part of the tensioning mechanism and have grooves machined into the surface to grip the belt teeth as shown in the photo below. One of the plates is slotted to allow it to be moved before locking in place.
Mike
October 05, 2018 10:20AM
I never "asserted that CA adhesive was unsuitable". I said I wouldn't trust it. I also don't trust zip ties to hold bearings in accurate alignment. YMMV.
Clamps are so simple and reliable, I can't imagine a situation in which I would use anything else, but who knows, maybe some day I'll have to glue a belt...
October 05, 2018 11:39AM
@leadinglight, yeah was your mechanism I was talking about, a lot of work gone into making that tooth profile, so the slide bit only looks good for a few teeth, whereas if there where no teeth it could be more adjustable, especially if there was a horizontal slit(2.5mm x6mm wide-ish) in middle between adjustment slots. (though i'm sure you've probably done it like that elsewhere & chose to do it the way you did for a reason)
Edited 1 time(s). Last edit at 10/05/2018 11:43AM by MechaBits.
October 05, 2018 12:28PM
@DD. I apologize as your post was several back and I was too lazy to look up the wording that you used.
@MechaBits. The tooth profile was surprisingly easy, it was milled on a 3D printer with a Proxxon hand tool.With the hex screws about two turns loose the belt could be pulled up like a zip tie (click click instead of ziiip) and the few mm of movement used to fine trim so that the belt had a pleasant twang.
Mike
October 05, 2018 02:08PM
thumbs up for using the printer as a CNC machine...gotta get me a dremel
October 05, 2018 02:16PM
There is a video of it being used for another job on [www.youtube.com]
As long as the machining is light then 3D printers do a good job but not to be confused with for-real milling.
Mike
p.s., perhaps we have moved this thread a bit far from it's origin so maybe need to discuss the limits of 3D printer milling in a new thread.
October 05, 2018 03:46PM
Ok Back on track...3030 has a wider slot than 2020 so a little more space for the belt, and probably better for the cantilever too.
I had the belt running in 3030 in this version, but have since changed the profile for something else.
So now I have to redo hotend part & idler as the clearance has changed.
Edited 1 time(s). Last edit at 10/05/2018 04:31PM by MechaBits.
October 06, 2018 06:47AM
@Mechabits The 3030 could be the solution, but Cetus does it with 2020... I'm kind of jealous...
So no one on this forum has a cetus to take a look at ? It's so sad that the price has gone up like that on those nice printer, otherwise I would have bought one just to see how it's made !
October 06, 2018 09:13AM
It's easy enough to design an idler that fits within a 20x20x40(or less if you put your mind to it) envelope(especially with stronger filament) using say 5x5x14mm(flanged but wouldnt matter) bearings x2 = 10mm with a little clearance.(or just one & smaller)
with something 40mm long and gt2 idler pulley with 3mm hole you could use 2 holes on the rail one through the idler & plastic, and another 3mm screw in next rail hole. or with the 5mm example the block could be held with just one screw if it was butted up against the 2020 so it wouldnt rotate plus belt keeping it secure too.
Edited 3 time(s). Last edit at 10/06/2018 02:05PM by MechaBits.
October 14, 2018 08:21PM
Archiclem... I built a printer in the design style of a Cetus. Here's the link to the respective forum thread. While I didn't put all the belts inside the extrusions, this might help. If you have any questions just ask.
October 15, 2018 03:11AM
MatthewHall
Yes I know, I've built and printed some of the part you designed, but I really like the idea of belts running inside aluminum extrusions smiling smiley And I nailed it this Weekend, I will post some pictures and design file soon... And i'm kind of going the "all metal way", using printed part only where I can't get metal to fit smiling smiley
