First layer adhesion October 09, 2018 02:31AM |
Re: First layer adhesion October 09, 2018 02:47AM |
not one bit will that help...Quote
If I scratch the glass with a sandpaper, this would help in the first layer?
is thermal plastic build plate from andornot build plate there other brands with pei sheets like gecko... now the problem with these thermal plastic sheets they work extremely well , where you can end up fighting and wrecking the Z axis, not so much of problem for you if stick with glass and plastic sheet but the other option with makes removing prints child play flexible bed thou am not sure how good that is with ABS or the higher temp filament.|
Re: First layer adhesion October 09, 2018 02:50AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: First layer adhesion October 09, 2018 02:55AM |
Re: First layer adhesion October 11, 2018 08:48PM |
Re: First layer adhesion October 12, 2018 04:51AM |
Re: First layer adhesion October 12, 2018 01:35PM |
Re: First layer adhesion October 13, 2018 06:02AM |
Lykle
Doug gave me a piece of polycarbonate and I have to say, wow.
No more adhesion problems.
In fact, I needed to sand it with 60 grit to slightly reduce the actual touching surface. No heat, it just sticks.
Used it with PLA, ABS and PETg so far. Oh and Ninjaflex.
Totally trouble free.
Also, because he was so kind as to give me some magnetic film with it, it is easy to pop off the parts.
Re: First layer adhesion October 13, 2018 09:29AM |
Re: First layer adhesion October 13, 2018 10:26AM |
