fast stepper motor October 22, 2018 07:27PM |
Re: fast stepper motor October 22, 2018 11:36PM |
Re: fast stepper motor October 23, 2018 04:41AM |
Re: fast stepper motor October 23, 2018 08:24AM |
dc42
The drivers on the Einsy are not capable of high current, which means it should be used with low current motors - which also means high inductance. So the Einsy is probably not the best choice if you want high speed.
Re: fast stepper motor October 23, 2018 08:47AM |
LoboCNC
If you want steppers to move faster, use as high a supply voltage as the driver chips and caps on your board will allow. (I think most ought to handle 24v at least.) Also, for a given size, try to choose a motor with the highest current rating your drivers can handle. These motors will have a correspondingly lower "rated" voltage, allowing them to be driven faster from, say, a 24v supply..
Re: fast stepper motor October 23, 2018 11:31AM |
Re: fast stepper motor October 23, 2018 11:55AM |
charlieRC
LoboCNC
Ok, I have some cheap amazon motors that are rated at about 2v per phase. I was looking at motors from another source (still not expensive) rated at 4v/phase. I was thinking the latter would be better, but your comment makes me think that the 2v/ph might be better... or am I over simplifying?
I will be using 24v ps. Do I really need to switch to nema 23s (assuming that the larger motor might provide more torque)
If you were in my shoes, can you think of a specific motor that you would use that has the best chance of over-coming the obstacles without breaking the bank?
Re: fast stepper motor October 23, 2018 12:33PM |
Re: fast stepper motor October 23, 2018 01:46PM |
Re: fast stepper motor October 23, 2018 03:24PM |
charlieRC
Sorry LoboCNC, didn't see your response before I posted above.
At this point, I seem to be stuck with trial and error.
Any suggestions about a controller? I was planning on using the eincy Rambo until someone said they don't provide enough power. I am now thinking about the Rambo Mini or just the regular Rambo, but not sure if that's any better. I am no loner sure what's out there and being used. (that's the problem with having a printer that goes strong for five years.....I loose touch about other products).
Re: fast stepper motor October 23, 2018 03:57PM |
Re: fast stepper motor October 23, 2018 11:46PM |
Re: fast stepper motor October 24, 2018 08:22AM |
Re: fast stepper motor October 24, 2018 09:21AM |
Admin Registered: 16 years ago Posts: 13,886 |
Re: fast stepper motor October 24, 2018 09:50AM |
Re: fast stepper motor October 24, 2018 10:02AM |
JoergS5
You can take fast steppers: normal size nema 17, low inductance like 1.8 mH. The calculated max speed is about 16 U/sec for a 2.5 A stepper (you need a controller capable of that), so for a Tr8x8(P2) spindle you get 128 mm/sec, which I think is enough.
I would take anti-backlash lead screws (screw with second short screw and spring between) to avoid errors with the many direction dchanges in the XY axes.
Re: fast stepper motor October 24, 2018 10:29AM |
Re: fast stepper motor October 24, 2018 11:25AM |
Re: fast stepper motor October 24, 2018 01:38PM |
Re: fast stepper motor October 24, 2018 04:42PM |
Re: fast stepper motor October 24, 2018 06:13PM |
Re: fast stepper motor October 24, 2018 06:42PM |
