What heater for Mic6 plate? November 07, 2018 07:17PM |
Re: What heater for Mic6 plate? November 07, 2018 08:14PM |
Re: What heater for Mic6 plate? November 07, 2018 08:52PM |
Re: What heater for Mic6 plate? November 07, 2018 09:27PM |
Re: What heater for Mic6 plate? November 07, 2018 10:10PM |
Re: What heater for Mic6 plate? November 07, 2018 11:51PM |
Re: What heater for Mic6 plate? November 08, 2018 07:10AM |
Re: What heater for Mic6 plate? November 08, 2018 07:57AM |
Number_5
I just ordered a 330mm x 330mm (13" x13") x 9.5mm (0.375") Mic6 aluminum plate.
Now I just have to decide if I want to go with a SSR and AC or 24V with a Meanwell PSU.
Re: What heater for Mic6 plate? November 08, 2018 07:27PM |
the_digital_dentist
I've never seen anyone reply to their own posts so many times, so quickly! No one can ever say you lack enthusiasm!
There seem to be a lot of crappy Fotek knock-offs around, so you did the right thing. You can get some idea of the time-to-temperature vs. power input relationship on this web site: [jscalc.io]
I use the same 750W heater on a 300x300x8mm plate and it gets to 100C for printing ABS in 4.5 minutes.
I put my printer's bed design on a blog page including the kinematic mount and info on a thermal cutoff to protect against SSR failure. I mounted the TCO on the bed plate, but it won't do its job if the heater comes off the bed plate, so it is best to put the TCO on the heater itself using high temperature silicone. I have recently found that the adhesive on the heater is starting to let go of the plate in my printer after two years of use. At some point in the near future, I'll peel it completely off the plate and reglue it with high temperature silicone.
Re: What heater for Mic6 plate? November 08, 2018 07:38PM |
Holy1
Number_5
Hi, great job updating your thread so fast. Can you give a link for the Mic6 plate? I am using the 750 watt keenovo pad with Cyrydom ssr too but my plate is only 1/8 thick.
Re: What heater for Mic6 plate? November 08, 2018 09:24PM |
Re: What heater for Mic6 plate? November 08, 2018 09:36PM |
Re: What heater for Mic6 plate? November 08, 2018 11:15PM |
Number_5
Last night I did come across others who were getting ATP 5 plate from a place in the states for pretty cheap, I think it was Midwest metals and around $35 US plus shipping for 3/8".
Re: What heater for Mic6 plate? November 09, 2018 04:58AM |
Re: What heater for Mic6 plate? November 09, 2018 10:06PM |
Re: What heater for Mic6 plate? November 09, 2018 10:23PM |
Re: What heater for Mic6 plate? November 09, 2018 11:52PM |
Re: What heater for Mic6 plate? November 21, 2018 12:17AM |
Re: What heater for Mic6 plate? November 21, 2018 07:20AM |
Re: What heater for Mic6 plate? November 21, 2018 08:55AM |
Re: What heater for Mic6 plate? November 21, 2018 09:35PM |
Number_5
For the record, I can't recommend that supplier I linked earlier for MIC6 plate. For the price of it, you would expect a pristine piece of metal, however mine has a couple of good dings in the one side that I am a bit annoyed .
Re: What heater for Mic6 plate? November 28, 2018 06:19PM |
Re: What heater for Mic6 plate? November 28, 2018 11:07PM |
Re: What heater for Mic6 plate? November 30, 2018 05:28PM |
Re: What heater for Mic6 plate? December 13, 2018 04:42AM |
the_digital_dentist
My experience with 2 different printers usiing PEI print surfaces and one with a Keenovo heater is that you've got about 2 years of reliable adhesion with the 200MP adhesive that Keenovo uses and the 468MP adhesive transfer sheets also use, if you're heating to ABS print temperature, and printing a lot (almost daily).
SoM has had the PEI restuck to the plate twice and it is starting to lift at the edges again. The PEI on UMMD (see image below) suddenly let go 2 days ago.
When the adhesive lets go of the PEI, it remains on the aluminum plate, but has lost all stickiness. I didn't check the heater to see where the adhesive is.
Re: What heater for Mic6 plate? December 13, 2018 07:34AM |
