Re: Best Auto level sensor & Extruder? November 16, 2018 02:25AM |
Re: Best Auto level sensor & Extruder? November 16, 2018 03:30AM |
Ed3D
(Probably a repeat thread so apologies if it is!)
Also what do you think is the best option for an extruder? Ive been looking at things like the nimble or the titan. Any thoughts? Anything open source?
Re: Best Auto level sensor & Extruder? November 16, 2018 02:57PM |
Re: Best Auto level sensor & Extruder? November 17, 2018 03:27AM |
Re: Best Auto level sensor & Extruder? November 17, 2018 10:31AM |
WesBrooks
With regards the original post I've tried the standard ormerod and mendel extruders, E3D titan, and Bondtech.the printed extruders worked well but didn't last well.
Re: Best Auto level sensor & Extruder? November 17, 2018 10:40AM |
Re: Best Auto level sensor & Extruder? November 17, 2018 12:18PM |
Number_5
The only flaw, or perhaps I should say compromise with Digital Dentist's build plate, is that the plate is indexed on one side. This should not be a problem if you leave the bed heated for the whole print. However if you only want to heat the bed for the first couple of layers, the bed will shift. How bad will depend on the location on the bed, the side opposite the indexing pin will see the full expansion of 0.5mm or 0.8mm, or whatever it is.
It may even move more then a "regular" heat bed fixed at 4 corners or 3 points, at least that may stay relatively centered.
Re: Best Auto level sensor & Extruder? November 17, 2018 07:44PM |
WesBrooks
With regards the original post I've tried the standard ormerod and mendel extruders, E3D titan, and Bondtech.the printed extruders worked well but didn't last well. I never got along with the Titan. Found it fiddly to set up, lacked power and ground filament when there were loads of retracts. That said it was consistant once setup. The bondtech is my favourite but I don't think it is the only double driven wheel setup. I guess there could be lessons to learn from mig wire drives. Think a few of them have gone to two sets of driven wheels, and I'd also like to try the belt extruders.
the_digital_dentist
Many people have worked out acceptable solutions to some of these problems and successfully print on glass every day.
Re: Best Auto level sensor & Extruder? November 17, 2018 08:00PM |
Re: Best Auto level sensor & Extruder? November 18, 2018 08:03AM |
Re: Best Auto level sensor & Extruder? November 18, 2018 09:07AM |
the_digital_dentist
The problem with indexing at the center of the bed is that you usually have a heater and/or thermistor there. Some heaters have a hole in the center or you could have a custom heater made that way. You probably wouldn't want to drill through the bed plate for tool access on the top side because slicers tend to put prints at the center of the bed, so you'd have to ensure that you can adjust the reference screw from the bottom side of the bed.
the_digital_dentist
When I said "heating the bed then dropping a few degrees". I did not mean warm the bed then turn off the heater. I meant print the first ABS layer at 100C then drop the bed to 90C or so for the rest of the print, or print the first layer of PLA at 70C then drop the bed temperature to 60C for the rest of the print. I don't know of anyone who heats the bed then turns it off during the print (but maybe I do now).
the_digital_dentist
Optical flatness isn't necessary for a printer's bed. +/- 50 um or so across the surface is adequate to keep the print stuck if you're printing the first layer 200 um thick. The leveling system does support the bed plate, so I'd guess that a much thinner piece of glass would be flat enough for a bed plate. But flatness isn't the only requirement. If you want prints to stick, you need even heating. Glass is a thermal insulator. As much as they try to make heaters with wide, even heat distribution, they are not perfect. If you stick a heater to a piece of glass, you will have an unevenly heated surface.
the_digital_dentist
Masking tape has nothing to do with providing a flat surface. It conforms to whatever surface it's stuck to. For some reason, molten PLA likes to stick to masking tape, even at room temperature. Until now, I've never heard of a coefficient of thermal expansion for masking tape.
Re: Best Auto level sensor & Extruder? November 18, 2018 10:30AM |
Re: Best Auto level sensor & Extruder? November 18, 2018 11:18AM |
the_digital_dentist
I can't follow your logic. You need print adhesion to the bed for the duration of the print. That's what the heater is for. You also need a surface that prints will stick to, which may not be the surface of the bed plate itself- people use different things- some print on glass with glue or hairspray, others use PEI or kapton, etc. I thought we were talking about 3D printers. I have no idea what Zerodur and telescope mirrors in space have to do with any of this. Glass is rigid and flat and is often clamped to crappy, unflat bed plates to provide a flat surface specifically because it doesn't conform to the unflat surface under it.
I'm so confused by your comments I have to ask a couple questions: have you ever used a 3D printer? Have you ever built one?
Re: Best Auto level sensor & Extruder? November 18, 2018 11:25AM |
Re: Best Auto level sensor & Extruder? November 18, 2018 11:50AM |
Re: Best Auto level sensor & Extruder? November 18, 2018 12:52PM |
Re: Best Auto level sensor & Extruder? November 18, 2018 03:59PM |
