Silicone Rubber Nozzle? November 18, 2018 09:29PM |
Re: Silicone Rubber Nozzle? November 18, 2018 10:04PM |
Re: Silicone Rubber Nozzle? November 19, 2018 11:34AM |
Re: Silicone Rubber Nozzle? November 19, 2018 11:59AM |
Re: Silicone Rubber Nozzle? November 19, 2018 01:02PM |
Re: Silicone Rubber Nozzle? November 19, 2018 06:11PM |
SupraGuy
This is a terrible idea from a control point of view.
If you do this, the nozzle diameter is linked to extrusion pressure. Pressure is linked to extrusion speed, which is in turn linked to print head speed. therefore, you need to extrude faster in order to print faster, but you also need to take acceleration into account, so this means that your nozzle will be getting smaller close to the corners, or the edges of the infill. Until or unless you can command instantaneous movement of the print head with no acceleration to speed, this isn't going to work. you'll also need to be able to do the same thing with the extruder, going from zero to full pressure instantly. No way this will end well.
You're also adding compliance to the nozzle position. There will be a tendancy to "drag" the actual extrusion point behind the centre of the nozzle. This is going to decrease accuracy, so you're probably better off just using a larger nozzle in the first place.
You're probably better off with a dual extruder, using a second one with a larger nozzle for infill. Actually, you're DEFINITELY better off doing it that way, since all of the provision to do that is already in place with firmware. With a large enough nozzle, you can also then do the "combine infill" thing to only have to do it every second or third layer.
Re: Silicone Rubber Nozzle? November 19, 2018 07:12PM |
Re: Silicone Rubber Nozzle? November 19, 2018 08:10PM |
Number_5
Here is what I was picturing when you mentioned this.
Inside the nozzle is a cone. This cone is there to keep the tip of the nozzle from bulging out, it's thicker then the rest.
The area around the cone is air, to give space for the cone to expand into.
The bottom is corrugated. This may or may not be needed, but could make it easier to expand without pushing the silicone downward.
The yellow paint represents the solid casing used to attach it to a standard hot end.
Re: Silicone Rubber Nozzle? November 19, 2018 08:11PM |
Re: Silicone Rubber Nozzle? November 19, 2018 08:48PM |
Re: Silicone Rubber Nozzle? November 20, 2018 01:14AM |
Origamib
Biggest problem I see is nozzle wear. Brass already wears down quickly, how will silicone fair?
Why not a silicone sock placed over a brass nozzle secured in place by a metal zip tie?
Re: Silicone Rubber Nozzle? November 20, 2018 02:21AM |
Re: Silicone Rubber Nozzle? November 20, 2018 02:23AM |
MechaBits
corrugated I thing you mean puckered annulus
Re: Silicone Rubber Nozzle? November 21, 2018 12:37AM |
Re: Silicone Rubber Nozzle? November 21, 2018 12:46AM |
Re: Silicone Rubber Nozzle? November 21, 2018 12:56AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Silicone Rubber Nozzle? November 21, 2018 01:04AM |
Dust
silicone doesn't stick to anything but silicone... (more or less) So it not going to adhere to a nozzle, not without some cleaver mechanical fastening system
Re: Silicone Rubber Nozzle? November 21, 2018 08:28AM |
Re: Silicone Rubber Nozzle? November 21, 2018 11:59AM |
Number_5
It's probably not worth trying to bind it to metal due to cost and also the dispensable nature of nozzles in general. It could be clamped to the hotend in various ways.
Re: Silicone Rubber Nozzle? November 22, 2018 01:25AM |
Re: Silicone Rubber Nozzle? November 22, 2018 07:54PM |
Dust
I suspect the issue will be that the pressure changes during normal printing. Using that same pressure to change the size of the orifice may not be practical.
Perhaps what is needed is a tiny silicone tire as a nozzle, having its own independent pressure system to adjust the orifice size. (probably liquid filled, as it doesn't compress)
