Can Micro stepping affect retraction and stringing November 27, 2018 03:50AM |
I have done it all and takes minutes to fix! |
Re: Can Micro stepping affect retraction and stringing November 27, 2018 04:23PM |
Re: Can Micro stepping affect retraction and stringing November 27, 2018 06:29PM |
Re: Can Micro stepping affect retraction and stringing November 27, 2018 10:01PM |
Nope but what I did say is that i have tried all the usual methods meaning all one would normally do and 99.9% of the links go to the same methods.Quote
dc42
...you've made it clear that you don't want advice, .....
Re: Can Micro stepping affect retraction and stringing November 27, 2018 10:03PM |
Re: Can Micro stepping affect retraction and stringing November 27, 2018 10:05PM |
Re: Can Micro stepping affect retraction and stringing November 28, 2018 06:36AM |
shearder
I am in an area with very low humidity. Have been for many years and printing fine fienthe last 8Quote
Number_5
How dry are you getting your filaments before printing?
Re: Can Micro stepping affect retraction and stringing November 28, 2018 02:00PM |
2. Adjusted temps from 220 down to zero extrusion temp
Re: Can Micro stepping affect retraction and stringing November 28, 2018 02:05PM |
dc42
When you say:
How low have you gone? Until the extruder can no longer extrude? Bear in mind that your hot end temperature readings may not be accurate..
Re: Can Micro stepping affect retraction and stringing November 28, 2018 02:10PM |
Re: Can Micro stepping affect retraction and stringing November 28, 2018 10:08PM |
Re: Can Micro stepping affect retraction and stringing November 29, 2018 11:50AM |
Re: Can Micro stepping affect retraction and stringing November 29, 2018 03:35PM |
Re: Can Micro stepping affect retraction and stringing December 20, 2018 07:24AM |
Number_5
shearder
Number_5
I had a feeling you were going to say that.
For the benefit of others reading this, dry your filament, all of it, regardless of where you live.
Re: Can Micro stepping affect retraction and stringing December 21, 2018 09:07AM |
Re: Can Micro stepping affect retraction and stringing December 21, 2018 09:36AM |
jamesdanielv
replace thermal couple with one that settings match your printer firmware. make sure to verify its calibration with an external thermometer if possible.
stringiness will always happen a little bit, but if it is not controlled, and stringing even below 160 deg c, then it might be an error with sensor readings.
you might have an uncalibrated, or malfunctioning thermal sensor.
change parts out cheapest to most expensive. if it is new, contact manufacturer and see if they can help you.
