3mm or 1.75mm feedstock May 18, 2011 04:16PM |
Re: 3mm or 1.75mm feedstock May 18, 2011 04:28PM |
Re: 3mm or 1.75mm feedstock May 20, 2011 05:45PM |
Re: 3mm or 1.75mm feedstock May 22, 2011 06:36PM |
Admin Registered: 17 years ago Posts: 1,472 |
Re: 3mm or 1.75mm feedstock May 23, 2011 10:25AM |
Re: 3mm or 1.75mm feedstock May 24, 2011 01:20AM |
Re: 3mm or 1.75mm feedstock May 25, 2011 05:38AM |
Re: 3mm or 1.75mm feedstock June 10, 2011 09:44AM |
Re: 3mm or 1.75mm feedstock June 10, 2011 12:01PM |
Re: 3mm or 1.75mm feedstock June 10, 2011 12:59PM |
3mm ABS is very reliable.
Re: 3mm or 1.75mm feedstock June 10, 2011 02:24PM |
Admin Registered: 18 years ago Posts: 7,883 |
How can Plastic be reliable?
Re: 3mm or 1.75mm feedstock June 10, 2011 03:12PM |
Re: 3mm or 1.75mm feedstock June 10, 2011 04:15PM |
sort of comments. Don't let it get to you. If your time or comfort level dictate that a kit or even a prebuilt machine is your best value then stick to your guns. I bought a makerbot before I decided to build a Prusa and I will continue using it after the Prusa is built. The right answer to what "should I build" depends on how you value your time vs your money, and how you rate your own ability to learn the required skills.
Re: 3mm or 1.75mm feedstock June 13, 2011 03:02PM |
Re: 3mm or 1.75mm feedstock July 22, 2011 12:55PM |
Re: 3-D printer November 24, 2011 05:56PM |
Re: 3mm or 1.75mm feedstock November 30, 2011 01:10AM |
Re: 3mm or 1.75mm feedstock June 19, 2013 07:27PM |
Re: 3mm or 1.75mm feedstock June 19, 2013 09:34PM |
Re: 3mm or 1.75mm feedstock June 19, 2013 10:01PM |
Re: 3mm or 1.75mm feedstock June 20, 2013 01:14AM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: 3mm or 1.75mm feedstock June 20, 2013 01:38AM |
Re: 3mm or 1.75mm feedstock June 20, 2013 03:24AM |
Re: 3mm or 1.75mm feedstock June 20, 2013 11:23AM |
Re: 3mm or 1.75mm feedstock June 20, 2013 12:32PM |
Re: 3mm or 1.75mm feedstock June 20, 2013 01:59PM |
Re: 3mm or 1.75mm feedstock June 20, 2013 05:46PM |
Admin Registered: 12 years ago Posts: 3,096 |
