Flexible spring plate thickness
Posted by tmorris9
December 24, 2018 04:05AM
Can anybody that uses flexible build plates tell me how thick their spring steel plate is? (not the bottom plate with magnets but the top plate that has the printing surface attached).
Going to try a DIY on my own but need a starting thickness.
Thanks
Re: Flexible spring plate thickness
December 28, 2018 12:11PM
I haven't used a flexible steel plate myself, but a 0.5mm should give you something with enough flex to pop a print loose. High-strength spring steel would be ideal. If you are using mild steel, though, you might want something a little thicker (0.8mm?) to keep from inadvertently putting a permanent bend in it.
December 29, 2018 02:03AM
At work we use very thin sheets to apply solder paste to PCBs. When I'm back from my holidays, I can take a closer look.
I'm a bit confused about ( nonmagnetic?) spring steel on printbeds?
December 29, 2018 04:01PM
o_lampe
Spring steel can either be stainless steel (most alloys non-magnetic) or regular carbon steel, which is always magnetic.
