Part Cooling Fan: How to Connect???
Posted by chiques
December 30, 2018 12:57AM
I'm using a Ramps 1.4 board with Marlin 1.1.9. I have a 12V fan mounted on my extruder. Which port do I connect this fan to so the firmware can control it? Also, what variable controls it?
Re: Part Cooling Fan: How to Connect???
December 30, 2018 01:05AM
How about reading the doc then eventually ask in the proper place ?
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
December 30, 2018 01:09AM
MKSA
I did and this sounds like a personal attack:
Personal Attacks In order to maintain a positive atmosphere, no personal attacks or insults will be tolerated. While discussions may become heated, it is not an excuse to resort to attacks or insults. Moderators and or Admins will remove and warn users at their discretion.
I'll be glad to post in the appropriate forum if you simply corrected me.
December 30, 2018 01:10AM
D9 is the normal port for the fan.
Its controlled with M106/M107
This is normally auto generated in your slicer.
This should not be confused with the hot end cooling fan, this should always be on on a ramps (as there is no mosfet for it, you would need to add one)
Ramps section of forum: [reprap.org]
Ramps documentation: [reprap.org]
Edited 1 time(s). Last edit at 12/30/2018 01:14AM by Dust.
December 30, 2018 01:12AM
Dust
OK, this makes sense since those ports are 12V. I was a bit confused since that port is labeled "Heat 2 , 9" on the PCB.
Thank you.
