Aluminum plate for bed
Posted by cozmicray
December 31, 2018 04:50PM
I have a
Hulamin m61 6061 T651 AMS 4027
aluminum plate (41 x 39cm)
Is this OK for printer bed?
I can't find 0.5AA spec
"M61 is a machinable plate that offers gauge and flatness tolerances to tighter than 0.5AA specifications"
Tnx
confused smiley
Re: Aluminum plate for bed
February 04, 2019 08:43PM
Hello, cozmicray.
Unless you are building a lab-grade machine (which would exceed the resolution of most 3D printing methods), don't worry so much about static surface flatness. The 0.5 AA specification is a pretty tight tolerance for flatness, but would be susceptible to warpage when heating unless the material is fairly thick. In most cases, for 3D printing, the warpage of most materials is negligible, and doesn't adversely affect the printed object. Other variations in the print will almost always be more noticeable than the relative flatness of the bottom layer.
In other words; don't sweat the technical specs for flatness. In case you're interested in learning more about Grade AA tolerance specs, check out this PDF.
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
