Hello All
My X and Y axis is pretty accurate. 100mm square is about 100.19mm square which is probably close enough.
Problem is my 2mm (designed) walls are 2.3mm wide. Skeinforge output gives me a wall of 2.02mm (when I calculate the centres of each side together with the layer width (calculated from layer width over height ratio) from the gcode.
I wonder if anyone has any ideas as to how I can get this more accurate?
Thanks
