Presenting: The Pyr0-Piezo Z-Sensor! A self-calibrating piezoelectric sensor
February 25, 2019 06:36PM
Hi there!
I recently published a project I’ve been working on for nearly two years, with the aim of solving the biggest issue facing cheap hobbyist 3D Printers: How to get a perfect first layer on any printer, using any type of hotend, and any print surface, even swap-able ones.
While this isn’t the first Piezoelectric z-sensor that’s been brought to the 3D Printing community, it is the first to incorporate an embedded microcontroller designed specifically for self-calibrating and conditioning the signal. Right now, the alpha boards being sent out into the wild don’t have full control over this circuit, but they already seem to produce good results. The Beta and final versions should only improve upon the principles and designs being tested now.
How the piezo z-sensor works: A small piezo element (commonly a 20mm or 27mm disk like the ones used in musical pickups) is fitted to a printer in such a way that when the nozzle touches the bed it undergoes a deformation or compression. When piezoelectric elements are subjected to mechanical forces in this way, they produce a charge. In the case of the z-sensor, this little blip of voltage produced by the piezo disk gets amplified, filtered, and conditioned by the Pyr0-Piezo circuit, then picked up by the board’s embedded MCU. The MCU then sends a z-trigger signal to the 3D Printer’s controller, and viola, you’ve got a Z-sensor. Since the MCU is using an interrupt pin for this function, it causes a delay of only a few microseonds, at most.
I’ve already finished about 12 sets of alpha (rev.1.x) boards that are going out to testers, but I will be looking for beta testers within the next month. If you’re interested, I’d appreciate a ping on the discord channel!
You can find source files on GitHub, Thingiverse, and my Discord’s #resources channel:
[github.com]
[www.thingiverse.com]
[discord.gg]
Re: Presenting: The Pyr0-Piezo Z-Sensor! A self-calibrating piezoelectric sensor
February 26, 2019 02:21AM
Is it possible to see the amp. schematic as a picture or pdf ? (the one on Thingiverse is too small)
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
February 26, 2019 04:43AM
Yes, all of the documentation* is available on the GitHub under docs: [github.com]
*Finished documentation. I'm still working on fleshing it out
Edited 1 time(s). Last edit at 02/26/2019 04:44AM by pyr0ball.
February 26, 2019 05:12PM
I'd be keen to be a beta tester.
One question: is this suitable for under-bed mounting? I'd rather mount under my delta's bed than hang it, and the associated wiring, on the effector.
Although the FFC sounds great too!
February 26, 2019 09:24PM
frankvdh
I did see you ask over on the discord, but I wanted to respond here as well. Yes the standalone version of this sensor would be suitable for under-bed mounted piezo disks
February 27, 2019 03:08AM
I wonder what it is you're trying to do with the outputs of U3C and U3D (see attached image) ?
Looks like you're trying to combine the outputs but very unsuccessfully. The output of U3D will have no effect (depending on the value of R4).
open | download - Strange_Circuit.jpg (77.4 KB)
February 27, 2019 03:24AM
Pippy
True. I was going to make this remark too.
Anyway, why not to use the ADC of the controller and do all level, filtering in firmware ? Just one OP Amp and protection in the front. Look how DC42 did it in his smart effector.
February 27, 2019 03:27AM
MKSA
I too thought this !
Using a little CPU should have made most of that analogue op-amp circuitry obsolete.
You don't even need an op-amp before the ADC, just a little RC filtering and diode protection. The signal from the piezo is very high in level.
February 27, 2019 04:02AM
Pippy
Exactly. Also the attiny processors have an optional ADC gain increase of up to x20. So the prototype piezo effector we designed used just an attiny processor, with no op amp. Whereas on the Smart Effector the signal from the strain gauge is measured in microvolts, so we do need the op amp.
February 27, 2019 05:47AM
Pippy
MKSA
OK if the controller can handle it. Note it wasn't to amplify the signal.
A piezo is a very high impedance high voltage source (In fact a cap with a minute amount of charge determined by the deflection).
Edited 1 time(s). Last edit at 02/27/2019 05:55AM by MKSA.
February 27, 2019 06:55AM
MKSA
Pippy
MKSA
The attiny processor ADC inputs are OK with any two of high resistance source, high capacitance source, and fast changing input. The datasheet gives the ADC input resistance as 100Mohms typical and a few pF capacitance.
February 27, 2019 06:56AM
dc42
I never realised a length of PCB track could become a usable strain gauge as you've done with your touch sensor. Nice idea and application !
I guess as the PCB is ever so slightly deformed when the nozzle touches the bed, the lower layer PCB tracks expand ever so slightly, and the upper layer tracks do the opposite ?
February 27, 2019 08:43AM
Pippy
Correct. The deformation of the PCB + belt + motor elasticity is small, about 0.1mm, and most of that is probably the belt stretch plus motor elasticity. So the signal we measure is small too, about 25uV to trigger. It needs a very stable voltage source and a low noise amplifier to make it usable.
February 27, 2019 10:43PM
Wow I need to check back in more often! Sorry for the delay in response.
I'll do my best to respond to everyone
Pippy
The voltage follower in this part of the circuit is attached to the amplification output via a 1megaohm resistor. This has two functions, first, in Rev.1.x it pulls the level of the signal attached to the noninverting input of the comparator stage to midrail, this allows for an adjustable "virtual ground" point (I'll go into more detail as to why I'm doing this later). The second function it serves is as a delay to the recovery time of the circuit, which provides part of the filtering. It's sortof, not really, but kinda hysteresis. In any event in my testing it's shown to help filter out smaller blips.
In the Rev.2+ (the version you screenshotted) part of the self-calibration involves raising or lowering the "virtual ground" using PWM and a low-pass-filter, which in turn, allows for an additional point of control over auto-tuning.
MKSA
Pippy
To my understanding, dc42's smarteffector is using software to capture an analog signal and then process it. I didn't want to do it this way for two reasons:
  1. I'm a hardware/electrical kind of guy, and my microcontroller programming skills are rudimentary at best. I wouldn't know how to implement what dc42 has done
  2. I'm using a hardware interrupt, which is VERY fast (like on the order of a few microseconds). From what I understand about dc42's effector, it's using an adc input and software to analyze the signal, which requires the adc pin to be actively polled
February 27, 2019 10:47PM
Just an FYI, I'll be hosting a livestream later next week explaining how the circuit works. I'll also be recording it and will upload to youtube/gfycat for later review.
I'm also very much open to suggestions, or design inputs if you guys want to contribute. This is just the best way I know how to do what I wanted. If there's a better way, I'd be happy to incorporate it!
February 28, 2019 02:14AM
pyr0ball
That's correct. But how fast does it need to be? We clock the ADC at 250kHz, giving a conversion time of 52us. We recommend probing at 20mm/sec. In 52us the probe travels about 1um. So that's the amount of jitter introduced by using the ADC.
February 28, 2019 11:36AM
dc42
pyr0ball
That's a very good question I hope to be able to answer after alpha/beta validation is done. At the moment I'm just not sure
ECJ
March 03, 2019 10:54AM
dc42
It was what I said two years ago here in the forum (https://reprap.org/forum/read.php?1,635075,760894#msg-760894), but it seems that some did not understand ... "DjDemonD" should remember well of my approach, because it was he who came in contact with me seeking a partnership. My "PiezProbe", which I've been seeing in Brazil for two years, uses only one Attiny and nothing else. Just develop the right software. Anyway, the use of attiny (without any other active component), is really a great solution.
March 03, 2019 11:26AM
I made a mistake in my earlier post, I should have said:
The attiny processor ADC inputs are OK with any two of high resistance source, low capacitance source, and fast changing input. The datasheet gives the ADC input resistance as 100Mohms typical and a few pF capacitance.
So driving from a piezo is OK, because although the source resistance is high and the signal changes quite fast, the source capacitance is also high.
March 03, 2019 12:24PM
pyr0ball
I was looking at the Direct Extruder FFC Breakout 1.0.0 schematics it floored be at first.
Was looking at the LM317DCY regulator and was confused by the use of OUTPUT_2 as a separate pin as you know they are internally connected.
Thous have never seen the distinction to lay it out as a 4 pin device. I have always seen the LM317 Layout as a 3 pin device.
Looked up the device and it indeed shows the LM317DCY SOT-223 as having 4 pins though the schematic layout shows it as a 3pin device.
This was intriguing for an Old School Tech, as they would start considering the heat dissipation tab a separate pin.
Thank You.
Noted in figure 24. of attached
March 03, 2019 02:54PM
As DC42 and ECJ say, there is no strict need for either buffering or amplification. The earliest use of a piezo disk for contact detection that I have found is on little maze running robots. Having said that, I presently use a single op-amp to give some pre-filtering (10Hz to 500Hz) and a little gain (X2.5) as well as a fairly high input impedance. The reason for the last is that I use an 8 pin PIC microcontroller to do my signal detection and Microchip reccomends an input impedance of not more than 10k.
Mike
March 03, 2019 04:39PM
You can ignore that Microchip recommendation of 10k if you understand the ADC and you know what you are doing. What's important is that the sampling capacitor (a few pF) can charge to the voltage you are trying to measure in the time you allow it. With 10K or less source resistance, that will always be the case. With higher source resistance, you can take additional measures to ensure it.
One of my working designs drives one of the ADC pins from a voltage divider comprising two 4M7 resistors, to measure the voltage of a 9V battery.
Edited 1 time(s). Last edit at 03/03/2019 04:40PM by dc42.
September 02, 2019 11:33AM
ECJ
dc42
Do you use selfcalibration or manual tuning?
September 02, 2019 02:04PM
Well there's been a lot of development since my last post. Got a rudimentary website up, as well as a documentation site, and I'm in the process of building and shipping out beta units for testers.
I did some rough tests on my breadboard/oscilloscope last week and found that the trigger signal actuation takes about 21.5uS (microseconds) on average from the piezo input to signal output, so it's extremely fast.
Here's the docs site (still working on filling it out): [docs.pyroballpcbs.com]
ECJ
September 03, 2019 09:24AM
karabas
ECJ
dc42
Self calibrated without any manual adjustment (since it was launched over 2 years ago).
Edited 1 time(s). Last edit at 09/03/2019 09:25AM by ECJ.
September 06, 2019 04:25AM
ECJ
karabas
ECJ
dc42
How about some pictures, schematic, video in operation ? I understand you don't want to have it copied and I understand you, so no need to give the firmware.
September 06, 2019 10:45PM
I have a few things posted around online.
My apologies for not linking them here earlier, as I kinda neglected this post after making it.
Documentation site (under construction, still filling things out when I find time)
The github has all of the schematics, Eagle source files, drawings, diagrams, and 3D Models I've made so far
Gfycat of one of the alpha boards running on a Monoprice Delta Mini.
Another video of that at a different angle
A little animation I built in Fusion360 to show how to install the mount on a Creality print head
Fusion360 model of the EasyPiezi 2.1.1
Fusion 360 Models of the Pyr0-Piezo FFC Print Head Board, and the Controller Breakout Board
I also built a little script that parses my git commits and outputs a changelog to the documentation site
Im sure Im forgetting something, but hopefully that'll get you some ideas of where the project is at the moment
September 07, 2019 03:57AM
@pyr0ball I was asking for ECJ schematic and pictures...
Indeed, as written before, the use of a microcontroller to treat the pizeo signal is the way to go in this digital age.
September 07, 2019 08:02AM
MKSA
............ Indeed, as written before, the use of a microcontroller to treat the pizeo signal is the way to go in this digital age.
As long as the production run is big enough to justify the programming time then microcontrollers are the way to go. My Op-amp/comparator based design cost about 25% more than my microcontroller one and the microcontroller (PIC16F1703) contains two op-amps and is able to drive LEDs without having a transistor to supply the current. That 14 pin microcontroller has enough processing power to do some remarkably sophisticated signal processing and can be tweaked or even completely reprogrammed without touching a soldering iron or turning a trim-pot
Mike
Edited 1 time(s). Last edit at 09/07/2019 01:42PM by leadinglights.
ECJ
September 07, 2019 04:36PM
MKSA
Ad where I make available for sale:
[produto.mercadolivre.com.br]
Specific to Ender 3 and CR-10:
Edited 1 time(s). Last edit at 09/07/2019 04:37PM by ECJ.
