Stepper Motor Torque Choosing Stepper Motors March 21, 2019 05:07AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 22, 2019 02:26PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 22, 2019 10:05PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:21AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:32AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:40AM |
etfrench
That may not have enough torque for a direct drive extruder. I'm using this one which has around 175 N-cm.
) and in fact so heavy that you will need bigger motors to move the gantry if you want to achieve decent speed. Besides the hobbed gear will be the limiting factor..|
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:50AM |
dc42
Don't go for a 12V 0.4A stepper, it is a very bad match for the constant current drivers used in repraps. Look for a motor which needs between 2 and 4 volts and has a rated current around 1.3A.
26Ncm torque is enough for an extruder with 3:1 gearing, but as @etfrench says, not for a direct drive extruder.
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 04:17AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 02:19PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 05:35PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 08:08PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 08:51PM |
KennTech
The Gen7 1.5v board uses a 12 volt buss that's why I choose the 12 volt stepper motor. The DRV8825 stepper motor driver says it can handle 7 - 47 volts but I don't know if it sets it automaticly or if I have to set it in the Marlin firmware. Plus the DRV8825 can handle current up to 2.5 amp. The stepper motor I'm getting only uses 0.4 amp so I figure it would keep the DRV8825 cooler.
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 11:22PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 01:22AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 04:11AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 04:25AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 06:57AM |
As nice as it was for dc42 to show me the EMF calculator, it only has 3 printer geometry and none are the Mendel90. I did save it for later use if I build a Delta printer. Plus I don't have the money to buy a 24 volt power supply. The 12 volt power supply was free out of a discarded computer.Quote
etfrench
See dc42's earlier post about the EMF calculator.
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 11:50AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 08:51PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 09:14PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 03:43AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 03:45PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 05:42PM |
KennTech
So Dc42 what you are saying is to look for the lowest EMF volt rating for any given stepper motor. Is that correct?
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 08:38PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 01:51AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 03:30AM |
KennTech
Hi Dc42,
Well my power supply is 12 volts and the DRV8825 driver boards can go to 2.5 amps. So I guess I'll look for motors that are up to 2 amps and around 2 to 4 volts.
But I'll have a time trying to find them not to many chooses online.
Thank you, Kenn.
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 03:53AM |
KennTech
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 02:43PM |
MKSA
Gee, you are making a mountain out of a molehill.
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 06:39PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 27, 2019 01:25AM |
