Stepper Motor Torque Choosing Stepper Motors March 21, 2019 05:07AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 22, 2019 02:26PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 22, 2019 10:05PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:21AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:32AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:40AM |
etfrench
That may not have enough torque for a direct drive extruder. I'm using this one which has around 175 N-cm.
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 03:50AM |
dc42
Don't go for a 12V 0.4A stepper, it is a very bad match for the constant current drivers used in repraps. Look for a motor which needs between 2 and 4 volts and has a rated current around 1.3A.
26Ncm torque is enough for an extruder with 3:1 gearing, but as @etfrench says, not for a direct drive extruder.
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 04:17AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 02:19PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 05:35PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 08:08PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 08:51PM |
KennTech
The Gen7 1.5v board uses a 12 volt buss that's why I choose the 12 volt stepper motor. The DRV8825 stepper motor driver says it can handle 7 - 47 volts but I don't know if it sets it automaticly or if I have to set it in the Marlin firmware. Plus the DRV8825 can handle current up to 2.5 amp. The stepper motor I'm getting only uses 0.4 amp so I figure it would keep the DRV8825 cooler.
Re: Stepper Motor Torque Choosing Stepper Motors March 23, 2019 11:22PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 01:22AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 04:11AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 04:25AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 06:57AM |
As nice as it was for dc42 to show me the EMF calculator, it only has 3 printer geometry and none are the Mendel90. I did save it for later use if I build a Delta printer. Plus I don't have the money to buy a 24 volt power supply. The 12 volt power supply was free out of a discarded computer.Quote
etfrench
See dc42's earlier post about the EMF calculator.
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 11:50AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 08:51PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 24, 2019 09:14PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 03:43AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 03:45PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 05:42PM |
KennTech
So Dc42 what you are saying is to look for the lowest EMF volt rating for any given stepper motor. Is that correct?
Re: Stepper Motor Torque Choosing Stepper Motors March 25, 2019 08:38PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 01:51AM |
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 03:30AM |
KennTech
Hi Dc42,
Well my power supply is 12 volts and the DRV8825 driver boards can go to 2.5 amps. So I guess I'll look for motors that are up to 2 amps and around 2 to 4 volts.
But I'll have a time trying to find them not to many chooses online.
Thank you, Kenn.
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 03:53AM |
KennTech
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 02:43PM |
MKSA
Gee, you are making a mountain out of a molehill.
Re: Stepper Motor Torque Choosing Stepper Motors March 26, 2019 06:39PM |
Re: Stepper Motor Torque Choosing Stepper Motors March 27, 2019 01:25AM |
