Stepper Motor Dampers WOW !!!!!! March 29, 2019 01:59PM |
Re: Stepper Motor Dampers WOW !!!!!! March 29, 2019 11:52PM |
Re: Stepper Motor Dampers WOW !!!!!! March 30, 2019 08:39AM |
Re: Stepper Motor Dampers WOW !!!!!! March 30, 2019 11:14AM |
Re: Stepper Motor Dampers WOW !!!!!! March 30, 2019 03:34PM |
MKSA
What happens when you tighten the belt to specs ?????
Better mount these dampers when there is no radial load.
Re: Stepper Motor Dampers WOW !!!!!! March 30, 2019 03:43PM |
Re: Stepper Motor Dampers WOW !!!!!! March 30, 2019 05:15PM |
Re: Stepper Motor Dampers WOW !!!!!! March 31, 2019 06:11PM |
Re: Stepper Motor Dampers WOW !!!!!! April 02, 2019 09:34AM |
bryanandaimee
In addition, you might also try smoother drivers, vibration isolating feet, grease your bearings. To test the isolating feet idea just lift your printer (safely) while printing. The noise often greatly decreases. This is because the desk you have the printer on can act as a speaker when vibrated by the printer. For printed dampers make sure you use ABS or PETG. PLA will quickly crack and fail.
