limit switch blanks Rep Rap smart controller lcd screen
April 05, 2019 09:36PM
I am building 3 printers and it does it on all 3
Rep rap smart controller to MKS Gen l, v1.0 board. Limit switch ebay purchase, normally open, tested with multi meter and functional.
Board only connected to computer and smart controller, firmware flashed and details on lcd, all good
Plug in limit switch and screen goes black, unplug and it returns.
Have changed the endstop in firmware to both true and false no change.
Any endstop will make screen black
I have built another printer with the same components in the past and all good
What am I doing wrong? really stuck
Re: limit switch blanks Rep Rap smart controller lcd screen
April 05, 2019 10:04PM
That is a very good question Post. Are you sure that the End-stop Switches are connected to the correct two pins.
April 05, 2019 10:29PM
Endstop plugs have 3 pins signal, gnd and 5v
Endstop switches should be between signal and gnd.
If the endstop is plugged in wrong, you short 5v to gnd and every thing stops.
April 06, 2019 01:11AM
I flipped the outer 2 wires and this resolved the LCD issue but now the printer doesnt see the endstops,
I can manually drive the z and y (direction X not working yet?) but when I trigger the limit switch on z and y nothing happens
Any suggestions?
Edited 1 time(s). Last edit at 04/06/2019 01:43AM by grunter.
April 06, 2019 01:37AM
get pronterface
run pronterface
connect to your printer in pronterface
Send the printer M119 command to view the current controller endstop status
view the status when the endstop is triggered and not triggered (trigger manually with a finger!)
If your endstops are just switches you need to enable the internal pull up in firmware
Your MOTHERBOARD must be set to BOARD_MKS_GEN_L for it to be looking at the correct IO pins.
April 06, 2019 03:09AM
G,day dust,
I am great at the mechanical but not so on the tech stuff.
Followed your instructions:
Did this and it says the end stops are triggered
Should I invert the setting in the firmware to be open, change to false. Sorry for the stupid questions, really out of my depth.
April 06, 2019 03:21AM
If they are reversed. Ie says open when it should say triggered or it says triggered when it should say open, but it does change from one to the other depending on if the switch is open or closed
Then yes invert the endstops.
If they don't change, its something else pullup resistors or motherboard settings, or plugged into the wrong endstop plug.
April 06, 2019 03:26AM
I will swap out the motherboard and lcd and start fresh with your instructions, to may issues.
thanks
April 06, 2019 04:29AM
Hi Dust,
all working perfect now, should have done that 4 hours ago, thanks for your help, I am always learning, now know about proterface. Your help with the limit switch got me on the right path Thanks for your time.
cheers
Grant
