Two filament runout sensors on one pin April 10, 2019 09:04AM |
Re: Two filament runout sensors on one pin April 10, 2019 09:36AM |
Re: Two filament runout sensors on one pin April 10, 2019 10:01AM |
Re: Two filament runout sensors on one pin April 10, 2019 10:19AM |
Dust
Your printing with T0, someone pulls the filament out of T1, (perhaps preparing for the next print) printing stops...
Re: Two filament runout sensors on one pin April 10, 2019 11:15AM |
Runout sensor : on/off
Re: Two filament runout sensors on one pin April 10, 2019 02:41PM |
Roberts_Clif
Marlin 2.0.x has the Option to turn the run-out sensor : (" on/off ") through the LCD control. Maybe something like this would better suit your needs.
You are in hte process of updating to marlin may be a good time to jump into Marlin 2.0.x.
I have and think it is great!!!
Re: Two filament runout sensors on one pin April 10, 2019 04:47PM |
Re: Two filament runout sensors on one pin April 10, 2019 06:12PM |
Roberts_Clif
I Upgraded to Marlin 2.0.x with My Hictop i3 Prusa MEGA2560 R3 controller that is ramps 1.3/1.4 ramps compatible, I believe it is more of a MKS Style Ramps because it will handle dual extruders.
I have installed it on Base v1.3, MPX.3 and MPK V1 controllers.
These controllers were previously configured with Marlin 1.x.x
#define MOTHERBOARD BOARD_RAMPS_13_EFB
#define MOTHERBOARD BOARD_RAMPS_14_EFB
An now Marlin 2.0.x
#define MOTHERBOARD BOARD_MKS_BASE_14
And have printed very good quality 3D Models.
In the Process of Adding 2nd extruder or Laser have not decided if the Laser should be on a separate Mostly Printed MPCNC yet...
Marlin 2.0.x controlled By OctoPrint using the Octolapse plugin.
[youtu.be]
Re: Two filament runout sensors on one pin April 10, 2019 07:01PM |
Schild0r
I read that marlin 2.0 only makes sense on 32bit boards because marlin automatically will take the 1.1.9 version to run on 8 bit. Is that true?
