Change Delta lateral start position?
Posted by StlLooking
April 16, 2019 11:42AM
Hi, what can I do to move the center-position on my Delta?
Most of what I print is a max of around 4" x 4" in base size. I have well worn patch in the centre of the bed and I'd like to make the thing think that the centre of it's world (X=0, Y=0) is offset to the side somewhere so that it can wear out another patch.
I know I can offset it in the slicer but half the time I forget (old and tired brain) smiling smiley .
What can I set in Marlin 1.1.9 to do this on a semi-permanent basis until I want to move the wear spot somewhere else?
Thanks
Re: Change Delta lateral start position?
April 17, 2019 12:48PM
That sounds to me like a thing to change in your slicer, just dont auto center your parts or change your center point in the slicer settings.
Edited 1 time(s). Last edit at 04/17/2019 12:49PM by sungod3k.
April 17, 2019 02:39PM
Thanks, I had already tried everything I could find in Cura 3.6 and 4.0 to offset the centre. I will now go ask on the Cura forum, but I may be stuck with manually repositioning it before slicing. Thanks anyway.
April 17, 2019 03:36PM
I suggest you check whether the build of Marlin you are using allows you to set either tool offsets or workplace coordinate offsets.
Edited 2 time(s). Last edit at 04/17/2019 03:40PM by dc42.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
April 17, 2019 06:15PM
Marlin 1.1.9:
Not that I can find for a Delta. There are probe offsets but it assumes that any "normal" person would want the print in the centre of the bed.
I was about to peel off the very ratty build surface then realized that 80% of it is still pristine, so why not use it.
Then I started moving it in Cura before Slicing -- when I remember that is. smiling smiley
