ExoSlide Linear Slides for 2020 Extrusion April 24, 2019 11:31PM |
Re: ExoSlide Linear Slides for 2020 Extrusion April 25, 2019 09:27AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 07, 2019 03:42PM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 08, 2019 04:53AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 08, 2019 09:15PM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 09, 2019 02:27AM |
Pippy
Very nice ! 3030 version would be nice too.
LoboCNC
Kinda pricey - $40 for a 4 sided slide. Is a 2 or 3 sided assembly rigid enough to use stand-alone?
Re: ExoSlide Linear Slides for 2020 Extrusion May 09, 2019 03:55PM |
LoboCNC
Re: ExoSlide Linear Slides for 2020 Extrusion May 09, 2019 08:28PM |
dlc60
LoboCNC
Not compared to a good linear slide. A 3-sided set would work fine it seems for deltas. I really hate the linear bearings for polished rods, they seem to gum up and go bad pretty often, so I am wondering if these could replace those as well.
Hmm
DLC
Re: ExoSlide Linear Slides for 2020 Extrusion May 09, 2019 10:08PM |
LoboCNC
dlc60
LoboCNC
Hmm
DLC
Plastic or steel rollers on extruded aluminum is never going to produce a great linear slide. The main problem with linear bearing on round rods is that people aren't using ground and hardened rods, which is a must.
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 05:27AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 06:09AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 08:02AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 08:13AM |
VDX
... what's more sensitive or problematic -- dust on "perfect" hardened surfaces ... or "averaging" the joint position with a bunch of plastic rollers on aluminium
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 09:21AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 10:39AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 10:46AM |
MKSA
VDX
Indeed but hard plastic roller on Al may be enough for a hobbyist 3D printer.
Anyway far better than ball bearings on EMT conduit (galvanized) or soft steel tube, AL profile that generates their own metallic dust
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 02:29PM |
obelisk79
So, being a user of vslot+wheels for linear motion for 3 years now, I fail to see the reason for all the negative references to it.
For me, it's been accurate and reliable. Maybe the sentiment is due to poorly made Chinese wheels? I have excellent accuracy and repeatability on my printer. Sure there are better options but they shouldn't be necessary in all circumstances.
Or have I misinterpreted the above comments?
dlc60
This product shows potential for both delta-style rail mount and bed-slinger style "rail" use. I have a Cartesian design in my head that I will modify for this transport type.
Re: ExoSlide Linear Slides for 2020 Extrusion May 10, 2019 02:55PM |
obelisk79
Re: ExoSlide Linear Slides for 2020 Extrusion May 13, 2019 01:12AM |
Re: ExoSlide Linear Slides for 2020 Extrusion May 13, 2019 02:04AM |
Re: ExoSlide Linear Slides for 2020 Extrusion September 26, 2019 04:07PM |
