Need Help - Customized 3d Printer April 25, 2019 03:02PM |
Re: Need Help - Customized 3d Printer April 25, 2019 04:27PM |
Re: Need Help - Customized 3d Printer April 25, 2019 04:47PM |
1. Your bed will weigh more about 1.2 kG for 3mm and 2.4 kG for 6mm aluminum plate.Quote
EzyMan
1- Is there any problem to change the hotbed to 400x400?
2- Is there any changes i have to do? in marlin?
3- Is there any risk regarding the power supply?
4- If i didnt change the hotbed and i put an aluminum plate above the current hotbed and i increase the heating temp. like from 60 to 90 degree as a special setting? is the printing will be ok?
Re: Need Help - Customized 3d Printer April 26, 2019 01:09AM |
Much appreciated.Quote
cozmicray
Gonna need a new heater
something like this (maintain 24v supply)
16" X 16" 400 X 400mm 24V 200W w/ 3M JSR2 Kapton Heater Heating Pad Mat
[www.amazon.com]
200W will not put too much of a strain on the 15amp Ender power supply
and a piece of 400mm x 400mm glass for the top
and a piece of something for the bottom bed
If you want it to heat up faster 120V AC heater and Solid State Relay to control it
other posts cover conversion to 120V AC beds
Re: Need Help - Customized 3d Printer April 26, 2019 07:31AM |
Re: Need Help - Customized 3d Printer April 26, 2019 10:02AM |
Re: Need Help - Customized 3d Printer April 26, 2019 05:29PM |
Re: Need Help - Customized 3d Printer April 28, 2019 06:59AM |
