Layer Shifting - Tronxy XY-2 Problem
Posted by EzyMan
April 26, 2019 10:11AM
Hi guys,
can anyone help me with this issue? just now i assembled this printer but the problem its coming like this:
Layer Shifting
[b.top4top.net]
Re: Layer Shifting - Tronxy XY-2 Problem
April 26, 2019 10:20AM
no idea what that is meant to look like...
Have you set the VREF on your stepper drivers to match your stepper motors?
April 26, 2019 10:33AM
i just assembled the printer and i run but all the models like this.
my stl file is an apple like the below:
apple
April 26, 2019 10:47AM
I can not tell in which Axis of the Model is shifting on,
Though I would guess that the concentric nuts are over tightened.
The XY Axis should move freely with a light push if there is too much pressure on the Belts or rollers with concentric nuts this can cause layer shifting.
Factory bearing are packed in some cases with a thick grease I have found that this packing grease should be cleaned and silicone or penetrating oil should be used.
Great Bearing Cleaning video
[www.youtube.com]
My bearing were not as bad though work much better after cleaning and re-lubing.
I tried a white grease an had more problems than the original packing grease.
Edited 3 time(s). Last edit at 04/26/2019 10:58AM by Roberts_Clif.
April 26, 2019 11:25AM
Could you measure the printed and model height, do they match? It looks as though the z axis missed steps or the driver overheated, binding etc.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
April 26, 2019 02:56PM
its all matching i dont know whats the problem
