If the holding torque were equal, the 0.9deg motor would provide twice the torque per unit lag angle, for small amounts of lag angle. In practice a 0.9deg motor will have a little less holding torque than a similar 1.8deg motor, but well over 50% of that torque. So the 0.9deg motor wins.
This assumes that you don't reach the speed at which the voltage needed to drive the requested current through the motor exceeds the supply voltage to the driver. That speed will be reached sooner on a 0.9deg motor than on a similarly wound 1.8deg motor.
Edited 3 time(s). Last edit at 05/01/2019 12:36PM by dc42.
