Problem with setting filament diameter in Cura 4.0 May 03, 2019 08:35AM |
Re: Problem with setting filament diameter in Cura 4.0 May 03, 2019 02:56PM |
Admin Registered: 12 years ago Posts: 3,096 |
David J
I used Cura quite a lot, up to the latest version, 4.0 - but now it seems incredibly difficult to set the filament diameter when slicing a part.
Nearly all of my filaments are slightly different sizes, so every time I plan to print a part with a specific filament I need to set its diameter. In the past I would just change the diameter in the 'materials' part of the setup, but that option seems to have disappeared. I have set all options to 'visible', so there's nothing concealed.
This may well be a user-ability error on my behalf, but it's very frustrating as, generally, I quite like using Cura. Can anyone tell me if I'm missing something here that's really obvious?
(On a Mac it's under Menu > Preferences > Printer > Machine settings).|
Re: Problem with setting filament diameter in Cura 4.0 May 03, 2019 04:28PM |
Ohmarinus
This option can now be found in the 'Machine' settings when you go to the Cura 4 settings(On a Mac it's under Menu > Preferences > Printer > Machine settings).
I think they want you to just specify the filament size you approx. use and then create different profiles from there. I personally tweak the E-steps/mm instead of tweaking the filament size since this both influences everything that happens during a print and is tweakable live so you don't have to go back into the slicer, generate a new gcode file etc etc. Best option i.m.o. if you have a printer with an LCD.
Re: Problem with setting filament diameter in Cura 4.0 May 03, 2019 06:08PM |
David J
Ohmarinus
I had found that setting - but it seems to be a stupid place to put something that's always changing. In previous versions it took me just 5 or 10 seconds to adjust the filament diameter - now it's a total PITA.
