Power Supply Inductor Repair
May 04, 2019 07:35PM
I have a 24V power supply that seems to have taken a hit in shipping and the inductor has come loose off the board. The legs have broken at the bottom in two spots. Is there an easy way to repair this possibly. I could possibly solder to the same holes in the board that still have part of the leg. I could desolder and maybe unwind a bit of wire and make longer legs which should be easier to resolder assuming I could figure out how it goes back in. I could also replace the inductor although I don't know the specs. Any thoughts / ideas would be apprecited.
Re: Power Supply Inductor Repair
May 04, 2019 07:46PM
Show me a photo of what you have. I can take a look though.
It is highly possible that you could solder a lead onto what is still there and extend the wire to the same hole removing the broken lead
Solder a wire of the same size paint with almost anything even nail polish route the wire the the hole and re-solder.
After use something that will help relieve the stress to the Transformer / inductor "hot glue ", "Silicone calk", an you should be good.
May 04, 2019 10:47PM
Here you go. The pictures are from both sides. You can see the broken wire and the hole it should go into. It's a bit tight of a fit so I may need to unsolder the whole inductor, extend the leads and then resolder? I have liquid electrical tape that I could use to seal when done and silicone caulk to hold in place.
Edited 1 time(s). Last edit at 05/04/2019 10:50PM by heatvent.
open | download - IMG_6609.jpg (668.2 KB)
open | download - IMG_6608.jpg (863.4 KB)
May 05, 2019 04:53AM
mmm that's totally fixable.
Looks like the wire has been cut too short for any solder to hold it in place.
I'd cut a short piece of solid core copper mains cable, solder that through the right hole and onto the wire on the inductor. Unless you have have solid copper wire laying around to use.
You might need to scrape a bit more insulation off that loose wire first to get a good soldered joint, difficult to tell.
May 05, 2019 09:31AM
This is very easy to fix.
Remove the solder from the mounting hole using any method, I use solder wick and a de-soldering solder sucker.
Both work very well in removing solder.
First I would Give it every effort I could to pull the wire as tight as possible to see if there is any chance you can place it back into the hole without extending the wires.
Then While pushing the wire into the hole with needle nose pliers solder generously.
If you do not succeed then try these options.
On the transformer / inductor loose wire remove some of the varnish to be able to get a overlap of the wires place another wire through the hole and align the two wires in parallel and solder.
If you think it is possible, It would be better if the two wires were twisted together then soldered. Though the transformer / inductor wire is fairly short and may be quite difficult to achieve...
Edited 5 time(s). Last edit at 05/05/2019 09:58AM by Roberts_Clif.
May 05, 2019 09:36AM
Thanks for the info. I think I will try the desolder and get it to reach approach first. Maybe I will get lucky. Just checking on this but it's not a good idea to unwind one loop rather than extend the end. I am not too knowledgeable of electronics and I am sure this would weaken what the inductor does but I am thinking it may still function well enough ... or is this a no-no?
May 05, 2019 10:11AM
Do not Unwind a single loop if you do you will change the characteristics of the transformer / inductor and it will not operate correctly.
Edited 2 time(s). Last edit at 05/05/2019 10:19AM by Roberts_Clif.
May 05, 2019 10:17AM
Thanks, that's kinda what I figured. We'll see if I can get these back in their respective holes on the mainboard.
May 05, 2019 11:05AM
This style power supplies are not to complex as far as switching power supplies go.
An Input
A Switching circuit
An Output
Shown below in this super simple switching supply circuit
The Transformer you are working with steps down the house current 100-265 Vac rectified to our source voltage for our output supply voltage of 12-24Vdc.
The TNY267 being the heart of this super simply switching supply.
Most Users will tell you that these power supplies are so cheap it is simpler to just replace, however what is the fun in that.
I believe this is the fun in having hobbies it is to learn all that there is you want to learn about them. To gain that little extra knowledge.
So what did I do when my power supply went bad - Purchased a new one, then before it arrived could not stand it any longer and fixed the bad one...
May 05, 2019 11:48AM
I agree, it's half the fun. I also couldn't see just throwing this in the trash. Although most of my 3D printing hobby seems to be working on the printer and printing stuff for it rather than anything else smiling smiley
Roberts_Clif
An Input
A Switching circuit
An Output
[attachment 111206 SimpleSwitchingsupply.jpg]
May 05, 2019 12:37PM
3D Printers are multiple hobbies all in one.
Computer Programming
Engineering / Design
Electronics Repair
3D Modeling
Its all good we learn what we deem necessary and I want to learn it all...
With My Next CNC project by V1 Engineering will be learning lots more.
May 05, 2019 12:39PM
It's not a transformer, it's just a smoothing/noise reduction inductor.
The transformer has yellow tape around the coils.
May 05, 2019 01:12PM
heatvent
Hahaha, this is so me. More than half the time I'm busy reworking my printer and trying out new stuff either in firmware or hardware.
Right now I'm thinking about ditching my classic MendelMax 1.5 design and rebuilding it in a self-designed V-slot 2040 beam frame. Much sturdier. I was having some severe issues with frame squaring and I found out that there is something wrong with the beams that I originally received 6 years ago when I started building this printer back in early 2013.
It never ends. But luckily now I have time to design and print the parts for a new designed printer and I see it as learning more about engineering and think that all these extracurricular work is always good to show in a curriculum vitae.
http://www.marinusdebeer.nl/
May 05, 2019 02:28PM
Pippy
Thank You.
May 05, 2019 08:25PM
Good news, I was able to get the wires extended just enough to solder back in the holes after removing the solder with a solder sucker. I have the supply back together and tested it out. No white smoke and 24.18V coming out the other end!
Only step left is to secure the inductor back down to the board. I have some 100% Silicone Caulk (like this [www.lowes.com]). Just want to double check to make sure this is good to use. I know somewhere hot glue was mentioned but this is going to run a 3D printer and can generate some heat so I wouldn't want to glue melting.
Thanks again for all the help!
May 05, 2019 10:01PM
That is perfectly except-able, you are merely taking added precautions that any vibration does not cause the part from releasing.
Edited 2 time(s). Last edit at 05/05/2019 10:03PM by Roberts_Clif.
May 05, 2019 10:55PM
hot glue is only good for one thing, making a project look unprofessional!!
May 06, 2019 01:58PM
Watch out with silicone caulk - plain caulk releases acetic acid as it cures which can cause corrosion. There are silicone caulks that do not release acetic acid but they are more expensive. Look at Electronics Grade Silicone.
May 06, 2019 02:01PM
Oops ... caulked it up last night. I will keep that in mind for the future. The link for the silicone product that you posted was about 1/2 the price of the power supply, so I would probably just have used the stuff I had on hand anyway. Thanks though, good information to know.
Edited 1 time(s). Last edit at 05/06/2019 02:13PM by heatvent.
May 08, 2019 04:56AM
I wonder which power supply it is you have ?
May 08, 2019 08:41AM
Just one of these cheap standard power supplies....
Link
Edited 2 time(s). Last edit at 05/08/2019 08:43AM by heatvent.
May 08, 2019 08:59AM
I designed a Case for this power supply. with a knob for an LED dimmer for case lights.
I used a LM317 voltage regulator adjustable for 0-12 volt supply.
Hictop24VpowersupplyCase.stl
Feel Free to modify for you own design, I used ThinkerCad
Edited 2 time(s). Last edit at 05/08/2019 09:12AM by Roberts_Clif.
May 08, 2019 09:17PM
Very nice, I will check it out. Thanks
