Connectors for hotend wires May 15, 2019 09:11AM |
Re: Connectors for hotend wires May 15, 2019 10:48AM |
Re: Connectors for hotend wires May 15, 2019 11:43AM |
Re: Connectors for hotend wires May 15, 2019 05:20PM |
Admin Registered: 11 years ago Posts: 3,096 |
StlLooking
Great, thank you.
Found them on Amazon and vendor ("Bretlux" or something close to that) seems to have a lot of Molex stuff. I will know where to look next time.
Re: Connectors for hotend wires May 15, 2019 05:28PM |
Re: Connectors for hotend wires May 15, 2019 05:37PM |
frankvdh
Molex micro-fit are good for 8.5A, and a bit smaller than the mini-fit range.
I've experimented with a couple of connector types, but haven't yet found anything that's cheap, easy, and good. A big issue with connectors here, especially on a delta, is strain relief. You need to ensure the wires don't flex relative to the connectors, or the wires will break at the crimps. A tidier, but more expensive, solution would be to put a bit of Veroboard on your effector/carriage, and connect from the controller to that, and from there to the heater/thermistor/fans.
Re: Connectors for hotend wires May 15, 2019 08:15PM |
Ohmarinus
frankvdh
I always thought the solution to compensate for wire strain, was to bundle the cables together with the bowden tube with something like spiral tube, sometimes adding in just a piece of 1.75mm nylon filament or something similar.
Re: Connectors for hotend wires May 16, 2019 03:25PM |
Re: Connectors for hotend wires May 16, 2019 05:47PM |
StlLooking
Hi, I would like to change out my hotend heating element as it is old and not keeping up with the demand printing at higher temps.
All the wires to the head are bunched in a cable chain and do not want to strip out the wires and snake the new ones in. I'd like to cut the wires at the head-end and install connectors for a simple swap over.
It is a 12v, 40Watt element so around 3.5Amps. What connectors can I get from Amazon that will handle that DC current OK? Something not too huge, like the XT-60 things, a 6-Amp version of those would be nice.
Thanks
Re: Connectors for hotend wires May 17, 2019 05:18AM |
Re: Connectors for hotend wires May 17, 2019 01:27PM |
leadinglights
I had never before found info on the XT30 and XT60 connectors but was so intrigued that I did a major search and found this [www.tme.eu]
Click on the PDF at the end of each description to get specification and dimensions.
I will go over to XT30 on my printers in the future. I had recommended Molex Mini-Fit as Micro-Fit were only rated to 4.7A in the very old datasheet I looked at.
Mike
