Show Off Your Work Bench! May 31, 2011 07:43PM |
Re: Show Off Your Work Bench! May 31, 2011 09:39PM |
Re: Show Off Your Work Bench! June 01, 2011 12:44PM |
Re: Show Off Your Work Bench! June 01, 2011 01:32PM |
Re: Show Off Your Work Bench! June 02, 2011 12:42PM |
Cupcake is printing happily with a glass platform and kapton on heated bed. The prusa is nearly done, Gen7 Electronics, everything moves correct distance on command, extruder isn't hooked up yet. Above the prusa is a prusa repstrap I worked on a little using composite deck board as vertices. Below is a mendel variant I am messing with using the vinyl washer vertex idea from Mrkim as seen here [www.thingiverse.com].
Re: Show Off Your Work Bench! June 05, 2011 12:14AM |
Re: Show Off Your Work Bench! June 05, 2011 06:34AM |
Re: Show Off Your Work Bench! July 10, 2011 11:31PM |
Re: Show Off Your Work Bench! July 11, 2011 08:13PM |
Re: Show Off Your Work Bench! July 11, 2011 08:47PM |
Re: Show Off Your Work Bench! July 12, 2011 06:22AM |
Re: Show Off Your Work Bench! July 12, 2011 09:05AM |
Re: Show Off Your Work Bench! July 12, 2011 09:52AM |
Re: Show Off Your Work Bench! July 12, 2011 10:11AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Show Off Your Work Bench! July 12, 2011 05:34PM |
Re: Show Off Your Work Bench! July 13, 2011 09:35AM |
Re: Show Off Your Work Bench! July 21, 2011 12:57PM |
Re: Show Off Your Work Bench! July 21, 2011 06:41PM |
Re: Show Off Your Work Bench! July 22, 2011 01:23AM |
Re: Show Off Your Work Bench! July 22, 2011 12:30PM |
Re: Show Off Your Work Bench! September 15, 2011 01:56AM |
Re: Show Off Your Work Bench! September 15, 2011 01:19PM |
Re: Show Off Your Work Bench! September 15, 2011 02:14PM |
Re: Show Off Your Work Bench! September 15, 2011 02:21PM |
Re: Show Off Your Work Bench! September 16, 2011 04:42AM |
Re: Show Off Your Work Bench! September 16, 2011 05:03AM |
Re: Show Off Your Work Bench! September 16, 2011 09:04AM |
Re: Show Off Your Work Bench! September 16, 2011 04:54PM |
Re: Show Off Your Work Bench! September 16, 2011 11:47PM |
Re: Show Off Your Work Bench! September 17, 2011 01:45AM |
