Change motor direction with Full graphic smart controller
Posted by BlueOrigin11
June 04, 2019 03:59AM
Hello,
i am building my own 3d printer.
As part of calibration process i need to reverse the motor direction to skip gantry back and forth.
I dont know if it is normal that you cant change the direction of your motors with the Full graphic smart controller.
So thats why i ask. Is that possible, did i oversee something in the configuration.h in Marlin?
I cannot calibrate printer if i need to remove the belt everytime gantry has reached end of printer.....
I need help please....
Kind Regards
BlueOrigin11
Re: Change motor direction with Full graphic smart controller
June 04, 2019 06:56AM
the LCD is for normal operation, not designed for setup or calibration.
Use a control program, such as printrun/pronterface
June 04, 2019 08:22AM
Ok. i will try this. Thanks a lot . Maybe its also bc i have not installed endstops yet.... eye rolling smiley
June 04, 2019 08:32AM
Ok. now works... Should have installed endstop before.... eye rolling smiley
Thanks a lot!
