AC vs DC Keenovo heated Beds June 06, 2019 04:08PM |
Re: AC vs DC Keenovo heated Beds June 06, 2019 04:36PM |
Admin Registered: 16 years ago Posts: 13,874 |
Re: AC vs DC Keenovo heated Beds June 06, 2019 04:39PM |
Re: AC vs DC Keenovo heated Beds June 06, 2019 05:00PM |
Re: AC vs DC Keenovo heated Beds June 06, 2019 05:25PM |
Re: AC vs DC Keenovo heated Beds June 06, 2019 06:06PM |
Forum-Layman
VDX
... for AC -- instead of wiring to mains, you can use tansformers with "harmless" voltage levels - used to heat my fist bed with a "12V-transformer" at roughly 16 Volts AC
I think that probably adds a little more complication!
Re: AC vs DC Keenovo heated Beds June 07, 2019 04:59AM |
Re: AC vs DC Keenovo heated Beds June 07, 2019 07:48AM |
Re: AC vs DC Keenovo heated Beds June 07, 2019 07:52AM |
etfrench
Why does AC wiring need to be in a conduit? Billions of AC appliances don't use conduit.
Re: AC vs DC Keenovo heated Beds June 07, 2019 08:22AM |
Re: AC vs DC Keenovo heated Beds June 07, 2019 11:49AM |
Re: AC vs DC Keenovo heated Beds June 07, 2019 02:05PM |
Re: AC vs DC Keenovo heated Beds June 07, 2019 04:05PM |
Forum-Layman
etfrench
In the UK at least all cabling must be double insulated (that's why the individual strands are encased within a black (usually) plastic insulation on kettle leads) so I would be surprised if you can find something with just single insulated and has exposed mains wires (essentially you should never be able to see blue / brown wires). The stuff that comes with the keenovo is 2 wires with a single layer of insulation on each so you would need to put them some kind of insulation to protect them and plastic conduit is just easiest and nicest looking IMO.
Re: AC vs DC Keenovo heated Beds June 07, 2019 04:13PM |
Re: AC vs DC Keenovo heated Beds June 09, 2019 05:55AM |
