3d printer fried stuff
July 09, 2019 04:49AM
Hi everyone,
I am a newbie to 3d printing, I tried to make a 3d printer but unfortunately I fried 2 mega and 2 Ramps 1.4 and I wonder if I can save the megas since an integrated burnt out. And I don't know how to check if a Ramps 1.4 burnt or not, and how to revolver that?
Re: 3d printer fried stuff
July 09, 2019 04:58AM
"integrated burn out" isn't that what "Boy racers" do?
Depends what died, and if you can solder... and if your time is worth nothing...
If its the main chip... not unless you can do surface mount soldering.
if its just the voltage regulator, (small black device, 3 pins and a tab out the other side, near the USB connector) only average soldering skills are required
if its the usb/serial converter... more surface mount soldering required...
As for diagnosing.. there is a book worth of information required to test everything on a mega,..
The basics: (general overview... not definitive by any means)
if you only plug the usb in, is there 5v on the 5v pins? (no there is probably a bad short... could be lots of things)
if you only plug in a 12v into the dc jack do you still get 5v? No dead voltage regulator
if you only plug in usb and the computer can't recognize the device and 5v pin has 5v. Its a dead usb/serial converter (presuming it used to work and thus is not a operating system driver problem)
if the usb is detected correctly and you upload the arduino flash demo and it wont upload its a dead mega2560 chip
if you have dead digital IO pins or Analog Pins, its a dead mega2560 chip
Edited 3 time(s). Last edit at 07/09/2019 05:20AM by Dust.
VDX
July 09, 2019 05:18AM
... most usual, when connecting endstops the wrong way, the +5V-regulator wrecks - this can be replaced with some soldering skills ...
Viktor
July 09, 2019 07:40AM
thanks for the help,
it is not about 'my time worths to something or not', but it is a curiosity to learn.
the stuffs which were burnt : voltage regulator, lm258.
and is there away to figure out which part of ramps was burnt(or possibly burnt) ?
anyway, thanks
July 09, 2019 07:45AM
thanks,
how could this be possible? I mean the endstops have a place to fit in and I think it fits like in the picture.
is there a way i miss something ?
open | download - endstop.jpg (210.2 KB)
July 09, 2019 08:34AM
timur
thanks,
That image actually looks like a Ramps 1.4a board to me instead of a normal Ramps.
http://www.marinusdebeer.nl/
July 09, 2019 08:57AM
yes it is.
July 09, 2019 09:07AM
timur
yes it is.
It makes a small difference, but there is an error in the board's layout that might be a good idea to be aware of.
The Robotale Ramps 1.4a is discussed in this video at the timestamp:
[youtu.be]
Edited 2 time(s). Last edit at 07/09/2019 09:08AM by Ohmarinus.
July 09, 2019 10:03AM
timur
thanks,
Shorting endstop normally happens when the user is using a two wire endstops. (ie a switch with wires, no pcb) They place the two wires on +5v and gnd (instead of Signal and gnd) resulting in the voltage regulator burning out
July 11, 2019 07:22AM
Thanks,
But i am using an endstop with 3 wires and pcb
July 11, 2019 07:36AM
timur
Thanks,
But I am using an end-stop with 3 wires and PCB
If this style of end-stop is accidentally plugged in wrong it too will destroy the 5 volt regulator on your Arduino.
This too will cause the end-stop to short from Power to Ground when using a three wire end-stop.
July 11, 2019 07:46AM
And then there is the 4 wire endstops (not so common any more) Signal, GND, GND, +5., which people bung it on the 3 pin connector, shorting gnd to 5v..
Basically be paranoid about your end stops.
July 11, 2019 01:06PM
Yeah, you can already see that the 3 pins of the endstop are not in the same order as the pins on the board. Big chance for a mistake. And then you sometimes have these endstops that come with white wires that are marked with stripes...
July 14, 2019 02:53PM
In Case of a short circuit due to endstop plugging in wrong direction, does the 3d printer works some time or burns immediately.
In my case, the printer worked for few minutes and then I pressed the heat option for bed and nozzle then a few seconds later, it started to smoke and burnt. (I dont know the reason, so I am trying to figure it out)
Thanks
Edited 1 time(s). Last edit at 07/14/2019 02:53PM by timur.
July 14, 2019 03:10PM
timur
Thanks
Do you have a photo of how you wired the hotend and bed?
July 15, 2019 04:40PM
here is the files.
bed-1 and bed-2 are the photos of the bed, and i got no led.
In reprap1.4 photo, the wires pointed out.
note: a motor driver seems connected in reverse order, after it burnt ı just plugged in and didnt touch again.
thanks.
open | download - bed-1.jpeg (117.4 KB)
open | download - bed-2.jpeg (141.5 KB)
open | download - reprap1.4.jpg (789.4 KB)
July 15, 2019 06:09PM
Are we looking in the correct place? A typical voltage regulator, when seeing a short-circuit situation, will simply "crowbar" and shut down, not burn up.
Same-same for thermal shutdown with high, but not shorted, power bus current.
A regulator burnout condition is usually because of a bad input voltage, either negative or too high.
DLC
Edited 1 time(s). Last edit at 07/15/2019 06:09PM by dlc60.
Kits: Folgertech Kossel 2020 upgraded E3Dv6, Anet A8 upgraded E3Dv6, Tevo Tarantula enhanced parts and dual-head, TronXY X5SA Pro(E3DHemera).
Scratch: Large bed Cartesian, exchangeable heads, Linear slide Delta, Maker-Beam XL Micro Delta, 220x220CoreXY.
July 15, 2019 08:15PM
timur
Thanks
When I plugged in my end-stop backwards it did not die quickly, as I just tapped the the switch blade to test using M119, it ran for a while then the LCD displayed garbage then it died completely.
After replacing the AMS1117 it started running, until I again went brain dead and shorted it out again this time making voltage measurements while adjusting the Stepper motor V-Ref.
I found this adjustable voltage
I finally replaced the Ramps D1 with a 12volt 3amp Dc-Dc step down converter so I could power the Ramps using 24VDC and the Dc-Dc step down converter would supply the Arduino.
Then I replaced the 5 volt AMS1117 regulator with the same regulator this time set to 5volt 3amp to replace the AMS1117-5.0
The AMS1117-5.0 dies with a simple quick short this part is extremely fragile.
July 16, 2019 03:21AM
The image of your controller seems to show that your bed thermistor is straddling one pin of T0 and one pin of T1
July 16, 2019 12:11PM
Roberts_Clif
timur
Thanks
I see your point - This part requires a special diode circuit to protect against short-circuit and even though it has thermal shutdown protection, the doc still warns about sustained high temperature use. But it IS really cheap... This part would not be my first choice.
DLC
July 16, 2019 01:25PM
Believe me this was not my first choice either, with bills getting higher and wadges lower it was my only choice, if I wanted a new MPCNC maybe later a better board could be acquired.
Even with repairs using the AMS1117-5.0 and then the DC-DC Step Down Buck Converter still much cheaper. An now the inadequacies of this cheaper controller are upgraded forever.
Roberts_Clif
July 16, 2019 04:05PM
Roberts_Clif
Roberts_Clif
Actually, I was talking about the designer's choice of that regulator. For another couple of quarters a better one could have been designed in.
DLC
July 16, 2019 07:45PM
So True!! An if the specs would allow this regulator use with a 24v supply as well it would be a prefect match for our 3D Printer environment.
Edited 3 time(s). Last edit at 07/16/2019 08:15PM by Roberts_Clif.
July 18, 2019 05:11AM
Dust
yeah it is kind of look like that but it doesnt.
any possibility for the problem caused from power supply unit. mentioned here : [reprap.org]
and i use a this PSU
Amper 30 A Transformer
Voltage 12 V
Operating Voltage 100 - 240V AC FULL REGULATION
Over Current Protection
Short Circuit Protection
Electrical Insulation Available
Noise Canceling Filter
AC Input Part With Cable Input
Standards CE, FC, TUV, GS, UL, FC, CCC (seen here [urun.n11.com])
thanks
Edited 1 time(s). Last edit at 07/18/2019 05:56AM by timur.
