Hotend not heating up August 05, 2019 02:47PM |
Re: Hotend not heating up August 06, 2019 02:27PM |
adrian_rg
The other day I was testing the extruder wiring. I pre-heated the extruder using Repetier-Host and the tempertature raised, but very slowly (to reach 190ºC it lasted between 3 and 5 min) and I started to suspect something was wrong.
Today I wanted to calibrate the extruder and when I pre-heated it, the tempreture did't raise (Repetier showed a oscilation between 20-21ºC, so the thermistor seems fine). Then I checked carefully if the metal block was heating, and it didn't get warmer.
Do you think it can be a problem of the ceramic cartridge?. Hotend fan is running fine and the led in RAMPS turns on.
This is the extruder (Titan Aero 12V version): www.aliexpress.com/item/32815903993.html?spm=a2g0s.9042311.0.0.2e4f4c4db6W5gL
The power supply is 30A 360W
