Availability of NEMA 17 Motor with 4mm shaft August 23, 2019 05:26PM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 12:49AM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 02:02AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 02:56AM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 03:46AM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 02:38PM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 04:47PM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 24, 2019 08:58PM |
sberesfo
Greetings,
We spent hours searching with Google for this configuration (before posting) with no success.
Thank you
Scott
Re: Availability of NEMA 17 Motor with 4mm shaft August 25, 2019 05:46PM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 25, 2019 10:13PM |
Re: Availability of NEMA 17 Motor with 4mm shaft August 26, 2019 05:52AM |
sberesfo
Hey Mike,
Thank you for the reply.
Ideally we would like to have about 60 oz-in at 100 RPM with a supply voltage of 12 VDC. This is possible for the larger NEMA 17 motors.
We could make it work if we could get that same torque at 60 RPM or if we needed to increase the supply voltage to 24 VDC.
Thank you
Scott
