Availability of NEMA 17 Motor with 4mm shaft
Posted by sberesfo
August 23, 2019 05:26PM
Greetings,
Is anyone aware of a source for a NEMA 17 stepper with a 4mm flatted shaft?
I saw a post in here that was a couple years old that indicated that this configuration might exist.
I realize that it is possible to custom order but I was hoping to find something off the shelf.
Thank you in advance for any advice.
Scott
Re: Availability of NEMA 17 Motor with 4mm shaft
August 24, 2019 12:49AM
Pretend the stepper motor is a lathe and turn the shaft down. One way to do this would be to secure the stepper motor to a workbench. Secure wooden platforms on either side of the shaft exactly 2mm above the shaft centerline. Run the stepper. Place a file on the shaft. Run until the file rests on both platforms (Or use calipers to determine when you've turned the shaft down to 4mm). You could also hand hold lathe tooling taking light cuts to achieve the same.
August 24, 2019 02:02AM
@etfrench
That is ridiculous!
Presuming you could take off any surface material at all, where do you think its going to end up?
That right it will be sucked into the stepper motor by the magnets and will f**k the motor.
DO NOT TRY THIS!
Edited 1 time(s). Last edit at 08/24/2019 02:03AM by Dust.
August 24, 2019 02:56AM
Nonsense, you can easily prevent any metal filings or dust from getting into the motor. Nema 17 motors are so inexpensive that you don't have anything to lose trying it.
August 24, 2019 03:46AM
BTW, why the OP needs 4mm ?
Why give an answer without having all the info about what he wants to achieve.
Besides, a guy who can't do a google search for "nema 17 4mm shaft" ????
Edited 1 time(s). Last edit at 08/24/2019 03:49AM by MKSA.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
August 24, 2019 02:38PM
Greetings,
We spent hours searching with Google for this configuration (before posting) with no success.
Thank you
Scott
August 24, 2019 04:47PM
A have several dozen old stepper motor datasheets and there is no sign of 4mm shafts even as an option on NEMA17 stepper motors. There are 4nm shafts on NEMA8 steppers and some of these have a possibly useful torque. Other steppers with 4mm shafts include pancake motors such as the Nanotech ST6318F1004-A from [uk.farnell.com]
If you gave a bit more info about your specification - such as required torque, then somebody may have useful ideas.
Mike
August 24, 2019 08:58PM
sberesfo
Greetings,
Thank you
Scott
And "Dorian" (https://reprap.org/forum/read.php?1,265113) is not likely to answer.
August 25, 2019 05:46PM
Hey Mike,
Thank you for the reply.
Ideally we would like to have about 60 oz-in at 100 RPM with a supply voltage of 12 VDC. This is possible for the larger NEMA 17 motors.
We could make it work if we could get that same torque at 60 RPM or if we needed to increase the supply voltage to 24 VDC.
Thank you
Scott
August 25, 2019 10:13PM
One of these will help turn that 5mm shaft to 4mm [www.ebay.co.uk]?
obviously you will need some other parts, maybe you can find a solid one.
[-MAAOSwkYZdOwOc" target="_blank" rel="nofollow">www.ebay.co.uk]
[www.ebay.co.uk]
Edited 2 time(s). Last edit at 08/25/2019 10:17PM by MechaBits.
[mechabits.co.uk]
August 26, 2019 05:52AM
sberesfo
Hey Mike,
Thank you
Scott
Hi Scott,
While NEMA17s with 4mm shafts seem to exist only as manufacturers surplus/over-runs, gearboxes seem to be much more available with a range of shaft sizes. First example I found was [www.amazon.com]
It should be possible to find some combination which gives the speed/torque characteristics that you want.
Mike
