Digital micrometer for positioning
June 06, 2011 05:13AM
Has anyone tried attaching a digital caliper to the X and Y axis?
I recently picked up a cheap one that has a port for connecting it to a computer. I haven't had time to investigate it but it seems to me that this could solve some of the problems with accurately positioning the print head.
Re: Digital micrometer for positioning
June 06, 2011 05:32AM
I think the issue with those is the frequency of measurements is a bit slow.
Perhaps it could be used to detect when there is a missed step.
June 09, 2011 05:45AM
A more usual way to do this is to add linear or rotary-encoders
to the axis. The result is stepper-motors operated as servo-motors
to reach abolute positions while detecting and countering missed stepps.
* homeprototype free 3d design repository
* Blog
* Google+
June 09, 2011 06:59AM
Digital Calipers are often used as linear encoders on machine tools see the following image.
Linear encoder milling
The data I think is sent 3 times per second from the port which may be sufficient. Here is another link to some info.
Interface
June 09, 2011 07:06AM
Well. that's all manual machines where an operator can read
the value with his eyes.
Last time I checked a RepRap didn't have eyes. winking smiley
3x a second means that even at slow 32mm/s you
have already moved 10.67mm between 2 meassurements.
Not enough for a closed feedback loop that tells a
stepper of 400 steps per revolvolution and <5mm
movement per revolution how far it has moved and
how to do minute adjustments to it's speed.
* Blog
* Google+
June 09, 2011 07:18AM
Thanks!
Once I get my reprap working smiling smiley I will start looking into this.
Even if it only checks the position immediately before starting the extruder, I imagine that print quality will improve.
June 10, 2011 04:46AM
Yes If you are using stepper motors 3 times per second would be enough as you are only verifying position.
We are confusing this with a closed loop system where the signal feedback is used to control the motor position in real time. This is how servo motors are controlled in CNC and you would need faster feedback for this.
One use I could see for what you are proposing is to set the initial datum of the print head before you start to print. Accurate postioning of the Z axis is vital when putting down your first layer to get good adhesion and avoid warping the part. It would be great if you could get positional feedback, particularly if you are doing multiple unattended builds. Perhaps you could spring load it to one side of the build platform to verify Z position.
August 29, 2011 04:54PM
the z axis doesn't move very fast so 3/second wouldn't be too bad.
Here are some resources for the output signal:
[www.compendiumarcana.com]
[mdmetric.com] (at the bottom of the page)
