CoreXY pen plotter jerky movement 8bit vs 32bit? October 09, 2019 05:40PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 09, 2019 11:28PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 09, 2019 11:39PM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 02:38AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 10:40AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 11:01AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 11:13AM |
Dust
You could try optimising your gcode
no need for all those z1.00 on the g2 or g3..., just wasting controllers time processing that part of the gcode line
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 11:24AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 10, 2019 11:40AM |
Dust
I don't know if removing all the Z1 will help at all... Its just something to try.
also consider using relative positions
ie after the initial set point go relative mode and then you only need to send the difference in position should be much smaller gcode file to process
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 12, 2019 09:40PM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 12, 2019 10:50PM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 13, 2019 02:26PM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 15, 2019 10:53AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 21, 2019 01:49PM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 22, 2019 06:41AM |
Re: CoreXY pen plotter jerky movement 8bit vs 32bit? October 22, 2019 08:15AM |
