How to tell if something is running Marlin?
Posted by WesBrooks
November 15, 2019 10:44AM
Hi All,
How can you tell if a system is using Marlin?
Any idea what the firmware for the Raise3D Pro2 is based on?
Thanks!
Re: How to tell if something is running Marlin?
November 15, 2019 11:25AM
Controller is reportedly based on Rumba.
November 15, 2019 11:43AM
Send an M115 through serial to the machine to see what firmware it has:
[marlinfw.org]
Edited 1 time(s). Last edit at 11/15/2019 11:43AM by Ohmarinus.
http://www.marinusdebeer.nl/
November 15, 2019 11:51AM
To legally be in a position where they had the option of not sharing their firmware source code as set up for their machines they would have had to re-write the whole code nase frm scrath rather than re write just a module or two right? I struggle to see the point in not circulating the source for a basic cartesian system.
November 15, 2019 12:06PM
I'm going to have to read this a few times!
"2. Open-Source Licenses. The Software may include one or more software components subject to an open-source license (“Open-Source Components”). Your use of the Open-Source Components is governed by, and subject to, the terms and conditions of the applicable open-source and public licenses. You understand and acknowledge that the Open-Source Components are not licensed to you pursuant to the provisions of this Agreement and that this Agreement may not be construed to grant any such right and/or license. You shall have only such rights and/or licenses, if any, to use the Open-Source Components as set forth in the applicable open-source and public licenses. Applicable open-source and public licenses may include, but are not limited or restricted to, Apache License 2.0, BSD 3-Clause “New” or “Revised” license, BSD 20-Clause “Simplified” or “FreeBSD” license, GNU General Public License, GNU Library or “Lesser” General Public License, MIT License, Mozilla Public License 2.0, Common Development and Distribution License, Eclipse Public License, and any other obligations, restrictions, or license agreements that substantially conform to the “Open Source Definition” as prescribed by the Open Source Initiative."
[www.raise3d.com]
Edit: The board is a Cortex M7 based system, so the chunk of code that is specific to the chip is lilely to be unique to this and a board called a 'speedy board'.
Edited 1 time(s). Last edit at 11/15/2019 01:39PM by WesBrooks.
